Thread: Shaking for side to side
Results 1 to 4 of 4
  1. #1 Shaking for side to side
    Memphis, TN
    My 2001 GT has been shaking from side to side when i get up to about 40. the tires are new and so are the springs and shocks/struts. before i start buying parts and replacing them, has anyone had this problem and what was the solution?
  2. #2 Re: Shaking for side to side
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    axle or axles seem to be a usual suspect on these grand prixs when it comes to shakes and vibrations.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: Shaking for side to side
    Wausau, WI
    did this just start doing it when any of those parts replaced, or was it doing it before you replaced them and now it still does it after you had the new parts put on?
  4. #4 Re: Shaking for side to side
    New York
    is the shaking in the wheel or more like the whole car? if the wheel is vibrating (like on the highway) it could be that the tires weren't balanced correctly....
  1. front drivers side sits higher than passengers side
    By tjvdubsport in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2009, 06:21 PM
  2. A/C cold on one side only?
    By SDGTP99 in forum General Tech Discussion
    Last Post: 06-06-2009, 06:56 PM
  3. Side mirror on driver's side
    By jokyfo in forum Shops and Community Heroes
    Last Post: 04-29-2009, 03:50 PM
  4. car swaying side to side!
    By Conrad in forum General Tech Discussion
    Last Post: 04-19-2009, 06:22 AM
  5. Side Decal
    By Shake_Zula in forum Visual/Body Modifications
    Last Post: 04-02-2009, 09:52 AM
