Thread: 2003 3.8 grand prix enigine noise
Results 1 to 20 of 29
  1. #1 2003 3.8 grand prix enigine noise
    SE Level Member broncos's Avatar
    montreal
    Hi everyone how is it going?
    I picked up a 03 grand prix special edition 3.8l, picked it up really cheap, just noticed a ticking sound when i rev it up real quick, but not when i rev slowly, one mecanic said it was the engine knocking, paid 900.00 for the car at an auction, no rust at all, about 110000 milles on it, changing my egr valve that went bad that was one of the codes i got, runs a litle better off then on, when i give it gas id just chokes, boggs, unless i let it pick up speed slowly, when i reach a hill forget about it its a disaster. found a 02 gtp engine with the same milleage for about 1200.00 and a year warranty if need so.
    please let me know what u all think.
  2. #2 Re: 2003 3.8 grand prix enigine noise
    GTX Level Member cerick08GP's Avatar
    Well, since you have no history with the car it could be a lot of things. Because you had a mechanic say it was knocking, I would change out the spark plugs ASAP. I would personally use Autolite 605s in your position.
    If that doesn’t work I’d move on to the MAF and MAP sensors.
    Good luck.
  3. #3 Re: 2003 3.8 grand prix enigine noise
    montreal
    i unpluged the maf and it still ran the same, i know there was a recall on some type of plug harness or somthing pontiac told me but they have a place only next week. shouldnt the engine knock at all times instead of only when i rev it up in neutral fast, and also while im driving when its starts hesitating and bogging u might hear it.
  4. #4 Re: 2003 3.8 grand prix enigine noise
    SE Level Member reveregtp's Avatar
    Nov 2008
    Revere, MA
    if its ticking, then perhaps its an exhaust leak, on top of that you may have a clogged cat
    id check those out as people tend to forget about them
  5. #5 Re: 2003 3.8 grand prix enigine noise
    montreal
    if it was the engine knocking wouldnt it knock even if i reved it up slowly at a high rpm or not, it does that knocking noise only if i rev it quick.
  6. #6 Re: 2003 3.8 grand prix enigine noise
    montreal
    if it was the engine knocking wouldn't it knock even if i reved it up slowly at a high rpm or not, it does that knocking noise only if i rev it quick.
  7. #7 Re: 2003 3.8 grand prix enigine noise
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    throwing any codes?
  8. #8 Re: 2003 3.8 grand prix enigine noise
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    i would check the fuel filter and pump
  9. #9 Re: 2003 3.8 grand prix enigine noise
    If it is knocking then it will knock ALL the time.
    This is a good example of rod knock. YouTube - MY 2002 WRX - Rod knock
    Could be a bad lifter too...that would be my bet...or a busted valve spring flying around in there and the rocker running all over the place. Take off the valve covers and unplug the ICM (the 7mm bolt in the front of the coil pack) then have someone crank it over and watch the rockers and see if they move up and down fine...if you notice one not moving right then that might be your issue on that particular rocker/valve...etc.
  10. #10 Re: 2003 3.8 grand prix enigine noise
    Quote Originally Posted by TurboTrav View Post
    How would that make a ticking sound?
  11. #11 Re: 2003 3.8 grand prix enigine noise
    montreal
    that's the type of noise it makes only if i rev it up real fast at the end it makes that type of knock when i rev it up gradually up to 4000 rpm it wont do it, also when i try to give it gas hard when it bogs.
    i'm changing the egr valve that was one of the codes, the other was tps sensor and 02 sensor in the back.
  12. #12 Re: 2003 3.8 grand prix enigine noise
    montreal
    ok it makes a sound like that when you rev it hard up to 4000 on neutral, also in park i try to keep the revs up at 4000 and they start to drop, i changed the egr valve and it still runs better unpluged, the air filter was completely blocked like i have never seen before, it was so dirty that it looked like black tar, tried it without the filter sounds louder runs just a litle better, but still bogs, and holds back like something wont let it go. if i drive it smooth it goes ok, it knocks only when it starts to bog and i try to force it sometimes. if i rev it normaly until 4000 i wont knock
  13. #13 Re: 2003 3.8 grand prix enigine noise
    I say broken flex plate then.
    YouTube - 3800_flexplate
  14. #14 Re: 2003 3.8 grand prix enigine noise
    montreal
    i read somewhere before about map or maf sensor cuting off power , it's like it wont accelerate when i try to push it only if i accelerate normally. when its holding back if i push hard on the gas it might knock.
  15. #15 Re: 2003 3.8 grand prix enigine noise
    montreal
    and fuel millage is horrible, worse than when i used kill my z28 or mustang at all times.
  16. #16 Re: 2003 3.8 grand prix enigine noise
    Wausau, WI
    Quote Originally Posted by broncos View Post
    The rev limiter wont let it go any higher....the pcm has a set rpm threshold that it wont let you go over in park/neutral so that you dont blow your damn motor. Almost any newer vehicle has this if it is an auto. If you want to go above that RPM range, you will have to do it in gear.
  17. #17 Re: 2003 3.8 grand prix enigine noise
    montreal
    Quote Originally Posted by a98gtp4u View Post
    throwing any codes?
    tps sensor, o2 sensor in the back, egr valve.
    changed egr no diff.. runs better unpluged.
    fuel mileage is horrible, no knocking during normal driving, though no acceleration, no power cant pass anybody
    I'm confused
  18. #18 Re: 2003 3.8 grand prix enigine noise
    Barksdale AFB, LA
    Clogged cat with probably a cracked flex plate.
    2009 Subaru Impreza WRX STI
  19. #19 Re: 2003 3.8 grand prix enigine noise
    montreal
    whats a flex plate and where is it
  20. #20 Re: 2003 3.8 grand prix enigine noise
    Don't worry about the flex plate. Please...
    This thread is a train wreck of guessing IMO.
    Can you get a vid of this knocking sound? That can help the diagnosis greatly.
  1. What is the correct bolt pattern on a 2003 Grand Prix GT
    By Dagujugrandprix08 in forum Tires & Wheels
    Last Post: 03-26-2009, 06:15 PM
  2. 2003 or 2004 grand prix?
    By dragonfox in forum General Tech Discussion
    Last Post: 02-16-2009, 11:53 PM
