Thread: Anyone know what this part is? Fuel system..
Results 1 to 5 of 5
  1. #1 Anyone know what this part is? Fuel system..
    Houston, TX
    Okay, so I need some help with a fuel leak I've had for quite some time now. I have the non-SC 3.8L and on my engine there are two fuel lines that come across the top of the engine and attach to the two fuel rails. The rear line has a large quick connect fitting, shown here:
    I have replaced the plastic quick connect clip that connects this fitting to the fuel rail many times, and still had a leak. So I finally decided to remove this piece and look inside, and sure enough there were two o-rings inside that were worn out. I bought some viton o-rings from oreilly but im not sure any of them were actually the right size.
    So here's my questions
    1. does anyone know what this part is called, or what the part number is?
    2. does anyone know how to put this fitting back on to the plastic line? this fitting has a 3-barbed end on it, but I can't get it into the plastic line past the first barb.
    3. Can I buy the line and fitting as one piece?
    Thanks in advance for any help, and let me know if you guys need more pics or info.
    Chris
  2. #2 couple more pics - in-car
    Houston, TX
  3. #3 Re: Anyone know what this part is? Fuel system..
    Houston, TX
    Messed up the last post, so heres the second pic...
  4. #4 Re: Anyone know what this part is? Fuel system..
    Houston, TX
    Noone can help with this?
  5. #5 Re: Anyone know what this part is? Fuel system..
    Wausau, WI
    Quote Originally Posted by cbeebe1981 View Post
    1. does anyone know what this part is called, or what the part number is? No, but take it to wherever you are going to buy a new one and they can look it up.
    2. does anyone know how to put this fitting back on to the plastic line? this fitting has a 3-barbed end on it, but I can't get it into the plastic line past the first barb. Lubricate it with something and it should slide back on-maybe something that will dry out like WD40?..but use it just enough so that it is not dry
    3. Can I buy the line and fitting as one piece?I have no idea, but wherever you take the part to to order it should be able to tell you what your options are.
    Chris
    Please see red above...
  1. My new fuel system...
    By Hellfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2009, 10:37 PM
  2. '94/'04 swap -- Fuel system
    By Orbital431 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2009, 01:52 PM
  3. Fuel System
    By joesforspeed in forum Turbo
    Last Post: 02-04-2009, 12:38 PM
  4. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
