Thread: Perpetual P0507 DTC. Replaced a lot of sensors...
Results 1 to 4 of 4
  1. #1 Perpetual P0507 DTC. Replaced a lot of sensors...
    Feb 2009
    NE
    97 GT. Cannot shake this "High Idle" P0507 DTC. I replaced the IAC & MAF sensors. I also swapped the TPS with my sons Monte Carlo with a 3.8L engine that is not getting any codes. I do notice when cold sometimes it can Idle pretty high but then it seems to idle down to normal when warm. I have no idea what to check/ change next to keep the SES light off? It is always just 1 P0507 code.
  2. #2 Re: Perpetual P0507 DTC. Replaced a lot of sensors...
    Donating Users kfish's Avatar
    Ohio
    throttle position sensor maybe? if you have a scan tool check and see what percentage it says the throttle is open, if any
  3. #3 Re: Perpetual P0507 DTC. Replaced a lot of sensors...
    Feb 2009
    NE
    I changed the TPS from a known good running car not throwing a code. Also, The TPS throws a code of its own if it is not working proper.
  4. #4 Re: Perpetual P0507 DTC. Replaced a lot of sensors...
    Unhook your throttle and cruise control cables to see if the issue remains. If it disappears, reconnect one at a time. I've seen them get moved slightly and cause a high idle.
    Messing with them usually cures the problem.
  1. Alt. Died. I replaced, Now my idle is wierd.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 09:22 AM
  2. For those who replaced 4th gear MPG increase?
    By a10tion in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-27-2009, 02:29 PM
  3. Perpetual belt squeak
    By Coogles in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2008, 09:07 AM
  4. replaced new blower resistor and still no heat
    By nemesis in forum General Tech Discussion
    Last Post: 11-02-2008, 12:29 AM
