Thread: Smells like FIre
Results 1 to 5 of 5
  1. #1 Smells like FIre
    Chitown
    I just bought a GP gt 2000....It had few problems almost with all gaskets. At first the car was shaking alot but it stop went the mechanic fixed it. Also I had the recall piece remove and install some part. Now that I drove it around away from the shop the car smells like fire even though there is no smoke coming out of the engine. What could it be? Does this car usually smells like this? or I am having some engine problems? Becaus even though the check engine light is on it has to do with the oxygen sensor plug at least thats what they told me at autozone store. Can one 1 please help would appreciate your help. this car had 139k
  2. #2 Re: Smells like FIre
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    strange problem. lets hope it has nothing to do with fire.....maybe they used some type of sealer that may take a little while to stop smelling.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: Smells like FIre
    Try cleaning the motor. Many times there is baked on fluids that heat up and smell bad.
  4. #4 Re: Smells like FIre
    Wausau, WI
    yes......clean the entire engine bay with engine degreaser and rinse off. It may take more than one can, if it has not been done in some time or you live in an area that is dirty or has dirt roads.
  5. #5 Re: Smells like FIre
    Chitown
    Thanks ppl I going to try to clean the engine hopefully the smell would change.
  1. Engine Fire
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2009, 12:26 PM
  2. Car smells like cig smoke and dogs
    By shawnz90 in forum Detailing Tips and Tricks
    Last Post: 08-30-2009, 09:21 AM
  3. my a$$ is on fire...lol
    By cojo in forum General Tech Discussion
    Last Post: 05-10-2009, 09:32 PM
  4. Mis-Fire #5
    By gtbeach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-06-2009, 11:39 PM
  5. Help!! 2004 Comp G Smells
    By dnnschuett in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 09:16 PM
