Thread: can u add an eaton m90 to an l36
Results 1 to 7 of 7
  1. #1 can u add an eaton m90 to an l36
    staten island
    i was just wondering can u add an eaton m90 to an l36 cause i dont have the money to do a top swap or engine swap i figured it would be easier to just bolt on the supercharger
  2. #2 Re: can u add an eaton m90 to an l36
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    top swap needs to b done
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: can u add an eaton m90 to an l36
    Charles City, IA
    Nope its impossible. You can never put a supercharger on a n/a car.
    SMGPFC Two Nipple General
  4. #4 Re: can u add an eaton m90 to an l36
    GTP Level Member Scimmia's Avatar
    QCA, IA
    That's kinda the whole point of the top swap.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: can u add an eaton m90 to an l36
    Norristown, PA
    OR..if you want to be a boss put a L32 in that *****
  6. #6 Re: can u add an eaton m90 to an l36
    lol, wut?
    an l32 wont make any more power than a top swap, BTW.
  7. #7 Re: can u add an eaton m90 to an l36
    L36 + Boost FTW...top swap it.
  1. Some interesting Eaton Information
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2008, 05:31 PM
