Thread: Top Swap Help
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 41 to 60 of 127
  1. #41 Re: Top Swap Help
    no, they cant tune with a tech 2. you need someone with a DHP Powertuner or HPTuners.
  2. #42 Re: Top Swap Help
    Donating Users kfish's Avatar
    Ohio
    Alright well there goes that idea. started checkin some more stuff out today. when i start it i get a massive amount of fumes out of the tail pipe and it smells like pure gas. pulled out the plugs and they all were black and practically dripping. i think my problem is probably the zzp pcm, right?
  3. #43 Re: Top Swap Help
    LMAO!
    Damn right that is the issue.
  4. #44 Re: Top Swap Help
    Ohio
    well i guess im screwed then...so you think if i order an intense pcm and put it in it'll run like a champ? haha im just worried about how its blowing air OUT of the intake
  5. #45 Re: Top Swap Help
    Backfiring OUT of the intake?
    Taken off of website...common intake backfire issues combined with fuel injection...
    A fuel injected engine may backfire if an intake leak is present (causing the engine to run lean), or a fuel injection component such as an air-flow sensor is defective.
    Common causes of backfires are:
    * Poor or unregulated engine timing is often a cause of intake backfires
    * Improper wiring in the ignition can also lead to timing issues and intake backfires
    * Low fuel pressure, clogged fuel filters, and weak fuel pumps could cause a severe lean air-to-fuel ratio during fuel injection
    So...instead of wasting money on a PCM (which you should eventually in the future because ZZP's blows ass) right now...get your fuel situation figured out. I tell you what though...I've got a set of stockers here...shoot me a PM if you want about them.
  6. #46 Re: Top Swap Help
    Ohio
    well im pretty sure the cat is toasted now...so should i do a catted dp? with a magnaflow cat? or just go uncatted? im in ohio
  7. #47 Re: Top Swap Help
    Ohio
    emailed zzp, of course they are blaming everything besides the pcm. tested the injecter harness with noid lights earlier. i have good pulse. also disconnected dp and tried running it and it still died. so the clogged exhaust theory is shot. im also now throwing a trans circuit code, says trans circuit input high prndl or something. any new ideas?
  8. #48 Re: Top Swap Help
    Wausau, WI
    burn your zzp pcm, and replace it with one that works. What do your plugs look like?
  9. #49 Re: Top Swap Help
    Ohio
    black and basically dripping gas
  10. #50 Re: Top Swap Help
    Ohio
    i think im gonna break down and order hptuners tomorrow...anyone got some tuning advice?
  11. #51 Re: Top Swap Help
    Are there no local Ohio GP guys that can tune it for you...should be WAY cheaper than just buying a HPTuners IMO.
    btw...replied to your PM sir.
  12. #52 Re: Top Swap Help
    Ohio
    i cant find anyone that can at least, i found a shop in toledo that does dyno tuning, but they want 475 to do it
  13. #53 Re: Top Swap Help
    Ohio
    im gonna list what i pulled out of the scanner today:
    DTC's
    P0101- MAF of VAF CKT Range/Perf
    P0300- Random/Multiple Cylinder Misfire
    P0706- Trans Range CKT Range Perf
    P1881- EBCM/EBTCM/PCM Misfire Detected Serial Comm Link
    Data
    AFR- 11.7:1 @ idle
    Baro Press- 4.8v
    Baro Press- 29"
    Calc Load- 48%
    FL Trim (BEM)CEL- 4
    IAC Mtr Pos- 17
    IAT @ Start- 54*F
    IGN Advance- -10*
    IGN- 10.90v
    INJ Pulse- 5.75
    KR- 0.0
    LT FL Trim 1- 39.8%
    LT FL Trim 1- 179
    MAF RAW INP- 1738Hz
    MAF (G/S)- 29.95
    MAP- 29.2"
    MAP- 4.7v
    02SEN1- 8.9mv
    02SEN2- 649mv
    Pass Mis Fail- 88
    ST FL Trim1- 128
    TOT- 2.37
    TOT- 66.2*F
  14. #54 Re: Top Swap Help
    what the hell is up with your LTFT? and your timing?
    what the hell is on that tune?
  15. #55 Re: Top Swap Help
    Ohio
    you tell me! its rediculous they are now trying to tell me im using the gt tb on the blower.
  16. #56 Re: Top Swap Help
    Wausau, WI
    they=zzp? I did not know that zzp would do custom tunes unless you took your car there. I would start with checking the tune and go from there. I dont know the tune details should look like, so I am no help. I know basically nothing when it comes to programming/tuning a pcm.
  17. #57 Re: Top Swap Help
    Ohio
    yea, now zzp is saying im running too small of injectors and making it run lean. hmmm isnt 11.7:1 at idle really rich?
  18. #58 Re: Top Swap Help
    Ohio
    alright, convinced them im running 33# injectors. Now they want me to use my stock gt pcm and drive it around for a little bit. Isnt the timing way too agressive for the sc? I just want my money back from these people haha. I got all the flow charts for my codes today at school, and i traced everything like it said and it all refers me back to the computer.
  19. #59 Re: Top Swap Help
    yeah...about that. if you use your GT PCM be prepared to take off your blower belt as well. the timing is higher and youll probably knock a lot if you get into boost heavily.
  20. #60 Re: Top Swap Help
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by kfish View Post
    my afr is 16.7:1 at idle...idk what that means exactly but my guess is really rich
    Now which is it, 11.7 or 16.7? One is rich, the other is lean.
    If you really do have L67 injectors and TB, using the stock GT PCM is a very bad idea.
    2001 Buick Regal LS - Almost Stock
  1. swap l67 for l32?
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-19-2010, 07:38 PM
  2. gto swap
    By CHAMPS97 in forum General Tech Discussion
    Last Post: 09-05-2009, 12:11 PM
  3. Top swap pcm
    By skidoojames151 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-23-2009, 03:47 AM
  4. top swap 05 gp
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-05-2008, 06:28 PM
  5. top swap
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 04:23 PM
