Thread: Top Swap Help
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 21 to 40 of 127
  1. #21 Re: Top Swap Help
    Donating Users kfish's Avatar
    Ohio
    im so sick of this car right now
  2. #22 Re: Top Swap Help
    Maybe the ICM itself is bad...
  3. #23 Re: Top Swap Help
    Ohio
    swapped it out too...i got a junkyard with 6 3800 series 2 right in my back yard.
  4. #24 Re: Top Swap Help
    misfires are a ***** to deal with. for the longest time my car misfired at idle only, but once i drove it a bunch more it ended up going away on its own. there are really only a few things it could be with the electrical system (ICM, coild, wires, plugs). once youve replaced all that its time to swap injectors to see if the misfire moves.
    have you gotten your car tuned yet?
  5. #25 Re: Top Swap Help
    Ohio
    yep it was the injectors bio, #1 was bad. anywho, go to the store and get a new one, 78 bucks. put it in hit the key and she purrs like a kitten . so me thinks its time for a nice easy test drive. i get about 10 miles down my road and turn right. car dies. try starting it, fires right back up. 1 mile late, it dies again. i **** for about 15 min lookin stuff over and try it again, and it fired up and got me home, but died pulling into the garage. so i check stuff out and try to start it again and its huffing air out the fwi. pull the valve cover off and put #1 at tdc and checked and both valves are closed, so its in time. i run it for like 5 min and look under the car, and the cat is cherry. it only does this while at full operating temp.....wtf?
  6. #26 Re: Top Swap Help
    Ohio
    and im running a zzp tuned ecm, i bought it cause it was decently priced and i just need the car to get me through till thanksgiving break and im going to have it dyno tuned. abs light is on, and i have the check engine light flashing, the codes are for the maf, and i cant remember the others...also while it was running, if i was about half throttle when i started feeling the boost, the engine would go up to 4k and bounce like it was on a rev limiter
  7. #27 Re: Top Swap Help
    Ohio
    come on guys, anybody?
  8. #28 Re: Top Swap Help
    Portland Oregon
    Dude you got some serious gremlins in there. I hope you get it worked out.
  9. #29 Re: Top Swap Help
    Barksdale AFB, LA
    You have a bad misfire which is causing the flashing CEL. Check your plugs and wires. If you start to get misfires or hesitation under boost, the plugs and wires are usually the problem.
    2009 Subaru Impreza WRX STI
  10. #30 Re: Top Swap Help
    Ohio
    new al104 plugs and wires....i dont know what can be causing this...
  11. #31 Re: Top Swap Help
    the cat is "cherry" as in red hot? sure its not clogged?
  12. #32 Re: Top Swap Help
    Ohio
    i got good flow coming out of the tail pipes, so i doubt its clogged, and yes red hot...like someone help a torch to it
  13. #33 Re: Top Swap Help
  14. #34 Re: Top Swap Help
    Ohio
    how?
  15. #35 Re: Top Swap Help
    Ohio
    i dont have a tuner
  16. #36 Re: Top Swap Help
    Ohio
    my afr is 16.7:1 at idle...idk what that means exactly but my guess is really rich
  17. #37 Re: Top Swap Help
    a tune...?
    16.7 is lean. usually at idle you should be in the 14.7 area, but i always ran mine a little leaner (15.0). it should bounce somewhere in the 13.5 area when cruising and WOT you should be running in the 11.5 area or better.
  18. #38 Re: Top Swap Help
    Ohio
    i think monday its getting dropped off at the dealership and let them get the gremlins out. i think that zzp pcm is ******* it up
  19. #39 Re: Top Swap Help
    Ohio
    the engine itself is super strong though since the rebuild. my buddy and i were messin around before the sc pulley got here and cranked it over and it had enough vacuum to turn the sc shaft, i figured thast was good...maybe its normal
  20. #40 Re: Top Swap Help
    Ohio
    they can tune with the tech2 cant they?
  1. swap l67 for l32?
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-19-2010, 07:38 PM
  2. gto swap
    By CHAMPS97 in forum General Tech Discussion
    Last Post: 09-05-2009, 12:11 PM
  3. Top swap pcm
    By skidoojames151 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-23-2009, 03:47 AM
  4. top swap 05 gp
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-05-2008, 06:28 PM
  5. top swap
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 04:23 PM
