Thread: Dogbones
Results 1 to 10 of 10
  1. #1 Dogbones
    Willoughby, Ohio
    i was looking online and i came across the zzp shorter dog bones...and then i came acorss the solid motor mounts. i was wondering if either of these would b a good investment? would either help out performance considerably?
    btw i have factory suspension and factory motor mounts and im installing my zzp 3 inch downpipe in 2 days so consider that too please
  2. #2 Re: Dogbones
    Portland Oregon
    Solid motor mounts are worthless. I had one from ZZP and it squashed in less than a year. Get yourself a regular fluid filled one, drain the fluid out, and get yourself some mix your own poly-urethane and make a poly mount. I can link you to a writeup that I did. PM me if you want it.
  3. #3 Re: Dogbones
    Jersey
    I have a set of zzp dog bones available for purchase, they're brand new.
    16' wrx sti- stock
  4. #4 Re: Dogbones
    Wausau, WI
    dont get shortened dog bones unless you have dropped your car. The mounts are really up to you...are yours shot?
  5. #5 Re: Dogbones
    Willoughby, Ohio
    Quote Originally Posted by Liquifire View Post
    no the r still good i was just wondering if there is any advantage over stock but im goin to have stock suspension until i move outta pittsburgh ha
  6. #6 Re: Dogbones
    Wausau, WI
    It is all a preference of how you want your car to feel. If you go with solids, you will get more vibration, etc. than if you stick with the stockers. The response gains are there, but minimal. If yours are OK, I would stick with the stockers. There are better mods to spend money on if yours are OK.
  7. #7 Re: Dogbones
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    why not? wont cars at regular height also benefit from the added torque, that is recovered by straightening out the cv shafts a little?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  8. #8 Re: Dogbones
    Quote Originally Posted by Jakegday View Post
    no. by doing this to a stock car you are forcing the axles out of alignment.
  9. #9 Re: Dogbones
    Quote Originally Posted by OH4CompG View Post
    And don't do this either...
    You can go to Auto Zone and buy solid rubber ones for cheap. Just ask for them.
  10. #10 Re: Dogbones
    Willoughby, Ohio
    ok thanks for the input guys...
  1. Dogbones?
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2009, 11:38 PM
  2. Want to paint dogbones
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2008, 10:56 AM
