Thread: dexcool coolant
Results 21 to 40 of 54
  1. #21 Re: dexcool coolant
    Oklahoma
    Quote Originally Posted by archemedes View Post
    cap should be replaced periodically anyway (usually they recommend I think once a year or every 2 years)
    GM has also changed or redesigned the cap as the one I got from them trying to troubleshoot my Dex Cool issue was a bit different from the OEM one that was on the radiator.
  2. #22 Re: dexcool coolant
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    the link i posted over in the what-mods-void-the-warranty thread denotes the different styles of caps and what ones are not reccomended anymore.
  3. #23 Re: dexcool coolant
    Feb 2008
    Innisfil,Ont
    Heres the update,got a call from the dealer they did a pressure test on the cooling system found all to be fine,they said they also added a dye to the coolant to see if any leaks in the next week and for me to periodically check the coolant level,if i see its continue to lose fluid to bring the car back.Igot till the middle of march b4 the exchange period runs out as soon i see any more fluid loss its going back and requesting a exchange.As for the sweet smell from the exhaust they have no comments on that.Also ask why the coolant level was low from the start they said it may have been a airlock?,Im not buying that.
  4. #24 Re: dexcool coolant
    Oklahoma
    Be ever mindful of checking the coolant level and checking for leaks and be persistent.
  5. #25 Re: dexcool coolant
    Feb 2008
    Innisfil,Ont
    When i was a the dealership today,checking out some Impalas and GP,when i checked under the hoods i notice that all cars have the same coolant level that way below the cold fill line,meaning there levels and mine were even with the return line to the rad.It that the normal level for dexcool or im just thinking old school that the levels should be up to the cold fill line?.
  6. #26 Re: dexcool coolant
    Oklahoma
    Im sure someone will correct me if I am wrong. But the overflow bottle is just that. It can only receive overflow from the radiator, not put it back in, as far as I know. I could be wrong on that so dont take it as gospel.
  7. #27 Re: dexcool coolant
    I live here. UR LOSN's Avatar
    Rockford, IL
    I have seen my level fluctuate.....it is well up when it is warm, and then when it is cold..I do believe that it can go back into the system when the cap opens..it will create a suction.and pull it back in.
  8. #28 Re: dexcool coolant
    Banned
    New Port Richey Florida
    yes what he said
  9. #29 Re: dexcool coolant
    GTP Level Member David99GTP's Avatar
    Florida
    Quote Originally Posted by UR LOSN View Post
    I believe you to be correct.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  10. #30 Re: dexcool coolant
    Oklahoma
    Well I did say I may be wrong, LOL. Looks like I may be.
  11. #31 Re: dexcool coolant
    Feb 2008
    Innisfil,Ont
    Well since i got the car home only one day,was out cleaning the driveway of snow noticed a few spots of antifreeze but the color is green not orange it may be the dye that the dealer put in also in the recovery bottle the level is down to half way.Will get my mechanic other than the dealers to see if he got a blacklight to confirm leaks b4 taken car back.Again thanks to all for your advise and opinions,What a great site.
  12. #32 Re: dexcool coolant
    Florida
    Scotty,
    well join the club LOL. I feel like a big dummy today because I cant get my new fuel rails to stop leaking.
    1999 GTP
  13. #33 Re: dexcool coolant
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by stoney81ta View Post
    I couldn't see the cold fill line and overfilled my overflow bottle once. I was sure my car was leaking coolant, but it was only pushing out the excess coolant out when it heated up and expanded. It was coming out the overfill drain tube on the firewall side of the coolant bottle.
    (btw, since the only place you are supposed to add coolant is the overflow bottle it has to be a two-way operation)
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  14. #34 Re: dexcool coolant
    Oklahoma
    Ive never used the coolant bottle to add coolant. Ive always let it cool down and popped the radiator cap and added coolant there. Even on my previous GP.
  15. #35 Re: dexcool coolant
    Florida
    Is it bad to fill at the cap? Just curious why its recomended not to. I usually add to the overflow, but like today when I had to top it off because I lost some due to removing parts I filled at the cap.
    1999 GTP
  16. #36 Re: dexcool coolant
    Bastard Reptile's Avatar
    Kansas City, MO
    It's not bad necessarily....but you don't open the coolant system up to contaminants that way.
    And my input also, it's a two way deal. It takes the overflow, but as the engine cools down, it will suck the coolant back into the system.
  17. #37 Re: dexcool coolant
    Oklahoma
    ^^ If he says its two way, then I believe it and so therefore I was incorrect (read: wrong) in my previous statement concerning that.
    But I am curious about the contamination statement however. Why would there be any less risk of contamination filling in the overflow than at the radiator cap?
  18. #38 Re: dexcool coolant
    SW Chicago Suburbs
    i theorize that any contaminants that would enter in the overflow, would settle in the bottom of the overflow bottle, since the tube that connects to the radiator is not at the bottom of the overflow bottle.
  19. #39 Re: dexcool coolant
    Kansas City, MO
    Well Scotty....by contamination I am referring to dex's sensitivity to air.
  20. #40 Re: dexcool coolant
    Oklahoma
    Quote Originally Posted by Reptile View Post
    Ahhh, I gotcha.
  1. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  2. Coolant Elbow Problem
    By Abrasive in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 08:39 AM
  3. Tefba coolant filters GROUP BUY !!
    By bayareagtp in forum Group Buys
    Last Post: 04-07-2008, 10:43 AM
  4. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
  5. Coolant Elbow Replacement on a 99-00 GTP?
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2008, 08:01 AM
