Thread: flex plate
Results 1 to 17 of 17
  1. #1 flex plate
    SE Level Member tihosick's Avatar
    meadville, Pa
    i have an 01 gp gt.. with 4 inch FWI and fliped dog bone rubbers.. jumpped om it from a light and my flex plate broke in two???? has this happen to anyone
  2. #2 Re: flex plate
  3. #3 Re: flex plate
    Jan 1970
    Maquoketa, Iowa
    To answer the question, they don't usually break on stock cars. But sounds like you beat the **** out of it sometimes, so yeah, somethings gonna break!
  4. #4 Re: flex plate
    meadville, Pa
    dont know if it was broke befor??? didnt sound like it.. and no i dont beat it all the time.. but when someone is beside you reving it up wouldnt you??
  5. #5 Re: flex plate
    Wausau, WI
    To answer your question......anything can break at any time, but these are not common to replace on our cars without reason very often. Probably just bad luck for you.
  6. #6 Re: flex plate
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by tihosick View Post
    yeah, if my kid wasnt with me it would be pretty hard not to.... that is some bad luck man. got a pic of that?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  7. #7 Re: flex plate
  8. #8 Re: flex plate
    Not always Bio.. sometimes they sound way worse.
    Things break.
  9. #9 Re: flex plate
    you dont have to tell me about things breaking. i broke my car A LOT.
  10. #10 Re: flex plate
    You say that in the past tense. I'm no quitter, still breaking my car.
  11. #11 Re: flex plate
    Ohio
    Intersting. im gonna go with the prob already cracked idea but really ahvent a clue. if u need another one i have one sitting in my garage at home looking for a good home
    00 GTP demodded and forsale
  12. #12 Re: flex plate
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by speedemongtp View Post
    fyi, It would have to be a GT flexplate or redrilled L67, they are different.
  13. #13 Re: flex plate
    Ohio
    O i had no idea nor did i take notice that he said it was a gt. thanks for the info thats something i def didnt know. so i guess i dont have one i have an l67 flexplate
  14. #14 Re: flex plate
    SE Level Member reveregtp's Avatar
    Nov 2008
    Revere, MA
    i broke an L67 one before... ****ty welding job by GM IMHO, check it out on youtube
    search for a video by skate4lyphe called "FLEXPLATE WHAT?"
    this was June 07 when that happened
  15. #15 Re: flex plate
    I probably have either if you are in need.
  16. #16 Re: flex plate
    meadville, Pa
    i alreaty gone it fixed ..but thanks.. i get some pic of it
  17. #17 Re: flex plate
    Wausau, WI
    post them then...
  1. Flex plate upgrade
    By rodman in forum Turbo
    Last Post: 12-12-2009, 12:25 AM
  2. 06 gp frame flex??
    By reallyfast1 in forum 04+ Specifics
    Last Post: 09-12-2009, 09:18 PM
  3. Flex Pipe
    By ARFF22 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2009, 09:59 PM
  4. noisy flex
    Last Post: 04-11-2009, 01:22 AM
  5. Cool Flex upper rad
    By TNTSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2008, 12:01 PM
