anybody have an estimate as to how much more i would have to spend for the rest of the parts? minus the tune
$150. Ish. For all the gaskets, the coolant elbows, etc.
Ha, Where did this $150 figure come from?
$50 for LIM gasket
$60 - 100 for Head gaskets
$30-100 for Head bolts
$15-30 for Rocker bolts
$15ish for coolant
$10ish SC gasket
$10ish TB gasket
$5-7 for coolant elbows
$50ish for synthetic oil
$30ish for valve cover gaskets
$10ish for RTV
$10ish for Thread locker
and more I'm sure I forgot, expect to spend just about as much on this junk as you did the hard parts
yeah............top swaps are not as cheap as everyone thinks, by the time this stuff is added into it, the tune, and the supporting mods that you should have.
Get everything from zzp EXCEPT:
Coolant and oil - walmart.
Head Gaskets - Autozone.
yeah, just get a gasket kit from ZZP. i even bought my head gaskets from there the first time i did it.
awful zone fails, it took 2 days for my one head gasket to come which was damaged, and the other one never came. I got a refund and went through zzp.
I go advance for things like that. They usually always have them in stock.
looking around zzp i found this on their site. is this worth it?https://www.zzperformance.com/grand_...ts1.php?id=382 .... also the gasket kit you guys mentioned is this it ...https://www.zzperformance.com/grand_...313&catid=103?
thanks for all the help guys
get this one:
cam install kit
then buy the head gaskets seperate.
alright kit 1,2,3 or 4?
....the one that contains what you need?
well im not sure what i need, hence why im asking lol
Well...do you need those things they list such as a cam/crank bolt and VC gaskets?! If not then No.
you want those things. since youre getting a cam.
Exactly.
o im getting a cam? lol wasnt really planning on it i just needed to know which gasket kit to get for the top swap
doing a top swap without a cam is fairly ill advised. it will make your whole world a whole lot easier if you get a cam right away. just get one that works well on stock heads.
