Thread: Low boost
Results 1 to 4 of 4
  1. #1 Low boost
    Modesto, California
    Hey all just finished up a full top end swap on my 98 gt and noticed im getting low boost readings??? Not sure if its how i hooked up my boost guage, if my reprogramed zzp pcm is wrong or if im forgetting something? ONLY Reading in the 4lbs area and know i should have at least 6? Any ideas or guage hook up pointers would be appreciated?
    Jason
  2. #2 Re: Low boost
    disconnect the vacuum line from the BBV.
    do people read write ups? it says it in the top swap thread like 50 times.
  3. #3 Re: Low boost
    Wausau, WI
    and this surprises you because.........?
  4. #4 Re: Low boost
    Jersey
    run open atmosphere
    16' wrx sti- stock
  1. Boost
    By Will5600 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2009, 01:14 PM
  2. How much boost?
    By Bigbm80 in forum General Tech Discussion
    Last Post: 07-09-2009, 04:01 PM
  3. only 4 lbs boost???
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2009, 04:50 PM
  4. boost??
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 06:59 AM
  5. More boost?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 07-25-2008, 12:33 AM
