Thread: New Guy With Code Problems
Results 1 to 10 of 10
  1. #1 New Guy With Code Problems
    Minnesota
    Hello,
    Here is the problem I am having. I have a 2002 Grand Prix with a 3.8 non-supercharged engine with 165,000 mile on it. The problem I am having is when you are excellerating hard or just crusing down the road it jerks once in awhile. It does no feel like a tranny slipping but just a sudden jerk. It also seems to be using more fuel than usual. This has been going on for about a month and just last night the check engine soon light came on. The two codes are P0102 and a P0650. What would you recommend I do and what parts should be replaced? I am use to working on old cars so this is new to me. I usually wrench on my 1977 TA not on the newer stuff. Thanks
  2. #2 Re: New Guy With Code Problems
    Dec 2008
    Lawndale, CA
    The P0102 code is for the MAF. You may need to replace it. One thing to try is to disconnect the MAF and see how it runs.
    OBD-II Trouble Code: P0102 Mass Air Flow (MAF) Circuit Low Input
  3. #3 Re: New Guy With Code Problems
    Minnesota
    What does the MAF actually do? Can it affect the jerking motion of the tranny or is it mostly for fuel / air mixture?
  4. #4 Re: New Guy With Code Problems
    Charles City, IA
    It tells the computer how much air is coming into the throttle body.
    SMGPFC Two Nipple General
  5. #5 Re: New Guy With Code Problems
  6. #6 Re: New Guy With Code Problems
    Wausau, WI
    Try cleaning the MAF sensor first, you may not need to replace it but if it is dirty it will not work correctly.........clean it gently with MAF sensor cleaner and get as much buildup out of the throttle body as possible........this should help a lot.
  7. #7 Re: New Guy With Code Problems
    Minnesota
    Do any of you have a quick snap shot of its location and is it easy to replace?
  8. #8 Re: New Guy With Code Problems
    Wausau, WI
    follow the airbox into the throttle body....I have no pictures.
  9. #9 Re: New Guy With Code Problems
    Minnesota
    Last night I bought a can of CRC MAF cleaner and used it. I did try and run the car with the MAF unplugged and when I stepped on the gas the engine would try to stall and when I plugged it back in there was no stalling issue. So does this mean the MAF is in good working order?
  10. #10 Re: New Guy With Code Problems
    Wausau, WI
    it sounds like it is fixed to me, but you are driving it. Is it driving normally now?
  1. p1133 ?? what is this code
    By 1bad3800 in forum General Tech Discussion
    Last Post: 12-14-2016, 12:12 PM
  2. I got a code!!!???
    By justwhisen in forum General Tech Discussion
    Last Post: 04-14-2010, 07:22 PM
  3. Engine Code
    By the955iman in forum General Tech Discussion
    Last Post: 04-17-2009, 04:40 PM
  4. engine code
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-15-2009, 04:42 PM
  5. code...
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 12:22 AM
