Thread: Lifter replacement
Results 1 to 6 of 6
  1. #1 Lifter replacement
    Donating Users kfish's Avatar
    Ohio
    Hey all, first time posting here. I got a 98 Grand Prix Gt. I got it about 2 weeks ago, got it cheap because it was ticking. I determined it was a lifter, so for the last 2 days ive been working on and off on the engine. I replaced all 12 lifters cleaned all pushrods replaced all gaskets etc. Did everything by the book. Now that Im nearing the time to start the engine is there anything i should do? Maybe disconnect the ignition module and crank the engine for a few seconds to prime everything?
  2. #2 Re: Lifter replacement
    Jersey
    Quote Originally Posted by kfish View Post
    Did u wash down the lifter valley with motor oil, then change the oil?
    I disconected the ignition harness and cranked mine over a few times, then the battery went dead
    I ended up starting the car with jumper cables, first start
    16' wrx sti- stock
  3. #3 Re: Lifter replacement
    Ohio
    ya i poured about a half quart thru the lifter valley, should i change oil before 1st start?
  4. #4 Re: Lifter replacement
    Jersey
    yeah change it before u start, you don't want to get coolant/oil mix going through your motor.
    16' wrx sti- stock
  5. #5 Re: Lifter replacement
    Ohio
    alrite will do, anything else?
  6. #6 Re: Lifter replacement
    Jersey
    i believe that's it, IMO change the oil again after 1k miles.
    16' wrx sti- stock
  1. lifter install?
    By 99prixgt in forum General Tech Discussion
    Last Post: 08-13-2009, 11:35 AM
  2. loud lifter noise any ideas?
    By breeze12 in forum Introductions/Noob Questions
    Last Post: 06-05-2009, 02:12 PM
  3. Bad Lifter?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2009, 10:03 PM
  4. Colapsed Lifter?
    By jbizach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2009, 08:48 PM
  5. Lifter Tick
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2008, 06:43 PM
