Can anyone tell me where to find the ECM on my 04 GP 3.8.L ? I checked the engine compartment but I don't know if I should be looking on the drivers side or passenger side.
It's inside the factory black plasitc air box. That is located on the drivers side and you have to remove the black radiator support bracket to remove the air box.there are three bolts which should be 12mm
Great , I'll check there .Thanks.
it takes up most of the bottom of the air cleaner box..........you cant miss it.
