Thread: Location of ECM
Results 1 to 4 of 4
  1. #1 Location of ECM
    canada
    Can anyone tell me where to find the ECM on my 04 GP 3.8.L ? I checked the engine compartment but I don't know if I should be looking on the drivers side or passenger side.
  2. #2 Re: Location of ECM
    TDCRacing
    Guest
    It's inside the factory black plasitc air box. That is located on the drivers side and you have to remove the black radiator support bracket to remove the air box.there are three bolts which should be 12mm
  3. #3 Re: Location of ECM
    canada
    Great , I'll check there .Thanks.
  4. #4 Re: Location of ECM
    Wausau, WI
    it takes up most of the bottom of the air cleaner box..........you cant miss it.
  1. GTP PCM location
    By razoredge in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-16-2008, 07:36 PM
  2. Custom Sub Box Location
    By HOPPY in forum Audio, Security & Visual Electronics
    Last Post: 08-22-2008, 12:09 PM
  3. Name this Part and location?
    Last Post: 06-24-2008, 08:37 AM
  4. pcm location
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 04-08-2008, 03:46 PM
  5. User location Map
    By 3800SE in forum Forum Bugs/Suggestions
    Last Post: 01-25-2008, 08:23 AM
