Thread: After cat oxygen sensor installation.
Results 1 to 13 of 13
  1. #1 After cat oxygen sensor installation.
    charlotte
    The rear oxygen sensor is in a differcult spot to get a wrench on to as it mounted vertically above the exhaust. Has anyone had any success using an offset wrench or an offset oxyegen removal tool? Do you have to removed the exhaust to get access? Any advice would be appreciated.
  2. #2 Re: After cat oxygen sensor installation.
    in a house
    Quote Originally Posted by English John View Post
    I would cut the u-bend section out and weld the o2 bung into a straight piece of pipe and mount the o2 horizontly. An exhaust shop shouldnt charge much to do this or you can order a u-bend delete from zzp with the o2 bung already mounted.
  3. #3 Re: After cat oxygen sensor installation.
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    when i was in that situation, the open end of a combination wrench is what worked for me.
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: After cat oxygen sensor installation.
    Ever heard of something called a o2 sensor socket? They work wonders and you can get them at your local auto parts store.
  5. #5 Re: After cat oxygen sensor installation.
    Nov 2008
    Fremont Nebraska
    good luck getting one on that sensor
  6. #6 Re: After cat oxygen sensor installation.
  7. #7 Re: After cat oxygen sensor installation.
    Quote Originally Posted by Jakegday View Post
    I've done it...not THAT impossible. Just takes a little beating.
  8. #8 Re: After cat oxygen sensor installation.
    charlotte
    Regular combination wrench did the trick. Thanks for the info. Saved me having to buy an un-necessary special tool.
  9. #9 Re: After cat oxygen sensor installation.
    Wausau, WI
    I prefer the sawz all method.........and u bend delete......all in one package.
  10. #10 Re: After cat oxygen sensor installation.
    california
    Hello there,
    I tried installing oxygen sensor on my car, and I used offset wench in it, and also, it does required to remove the exhaust to get access.
    just check this one for more: Oxygen Sensor Replacement
    hope this could help.
  11. #11 Re: After cat oxygen sensor installation.
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    I had no issues getting my O2 sensor socket on there, using a breaker bar it actually came off easier than most I have fought with. Mine looks like this one:
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  12. #12 Re: After cat oxygen sensor installation.
    Nov 2008
    Fremont Nebraska
    well thats a neat looking socket. it looks nothing like the oxygen sensor sockets ive seen. the ones ive seen would be a ***** to get on there, and if you did get it on, there was NO way of getting the socket wrench on top of it afterwards
  13. #13 Re: After cat oxygen sensor installation.
    Yup...the one Josh posted is what I used.
  1. oxygen sensor
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 06:20 PM
  2. sub installation
    By riley34 in forum Audio, Security & Visual Electronics
    Last Post: 11-18-2008, 12:14 PM
  3. HV3 Installation
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-18-2008, 09:37 PM
  4. Car Alarm Installation...
    By Guitarist575 in forum General Tech Discussion
    Last Post: 07-06-2008, 10:50 PM
  5. Falling mileage w/ new oxygen sensor.
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-23-2008, 07:48 AM
