Great info on LIM on the 3.8!
While in there I decided to do a compression check and found #6 at 90 PSI when the others were around 190. Did a leak down test and air was pouring out the exhaust. Pulled the head and crack goes between intake and exhaust on #6. Is this from too much heat? Go hot once with the coolant leak from the LIM. Anyone have head bolt torque sequence and do both long and short get 37# on the first pass and 120 degrees on the second?
Motor had 140K on it and I pulled it out as I am going to replace the pan gasket, water pump, timing chain and dampner etc. I don't want any issues for a while!! Any advice?
Motor is on a stand in my garage.(Proably should have bought a long block by now with these gasket prices!!
