Thread: icm question need a little help please
Results 1 to 6 of 6
  1. #1 icm question need a little help please
    DESOTO MO
    will any icm work from a 3800? or are the specific. installed
    new crank sensor today and it cranks kinda funny like an old car
    that jumped time but before all that it would just up and die
    might start back up might not for a while.
    then finally i had to have it towed and its dead in the drive way
    this is my only car please help
    is there a way to check the icm when its not runing
  2. #2 Re: icm question need a little help please
    Banned - Busted For Scamming
    Feb 2009
    Any way to check the icm? Not really unfortunately. They are kinda funny like that, could just up and quit one day, could be intermittent. Swap with a good known. Have you ruled it out, done other tests? What exactly is it doing before it dies?
    Ignition Control Module BTW, fires the coils, injectors too i believe on these cars.
  3. #3 Re: icm question need a little help please
    DESOTO MO
    no stuble or nothing just like you turned off the ign
    25 or 75 mph doesnt matter but always started back up untill well one day it didnt
    checked for broken wires also that lead to cs
  4. #4 Re: icm question need a little help please
    Feb 2009
    Fuel pump die? You really need to do more of the basic tests and go from there.
  5. #5 Re: icm question need a little help please
    DESOTO MO
    I replaced the pump because the gauge was bad
    and it did it before
  6. #6 Re: icm question need a little help please
    Wausau, WI
    crank position sensor? Sorry.........didn't see where you already replaced this ...
  1. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  2. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
