Thread: Rough Idle
Results 1 to 11 of 11
  1. #1 Rough Idle
    GT Level Member hacket's Avatar
    USA
    Hey guys,
    I posted about this a while back, but I haven't done anything to remedy the situation. (changing plugs or wires)
    Doing a little more research this morning, I'm thinking it may be my IAC valve acting up. The car has 166,500 miles on it, so it's probably never been replaced. The problem comes when the car is idling, not during driving. The engine RPMs will go up and down slightly, and about every 1-2 seconds I'll feel a slight tremor under my butt. Obviously a rough idle.
    However, I don't know where the IAC is. Does anyone think this is the problem, and if so could you tell/show me where it is?
  2. #2 Re: Rough Idle
    Donating Users mystic231's Avatar
    Michigan
    Yes and.......Yes
    The IAC valve is on the front side of the throttle body, round, and held on by two screws. There is an electtrical connector going to it with four wires in it. Get it from NAPA and I believe it has a lifetime warranty (with receipt). Easy 10 minute repair job.
    The key is that it only occurs when idling, not driving. The IAC is there to meter air into the engine when idling because the throttle butterfly is all the way shut, so no air getting in there. The IAC pintle gets sticky and is unable to move freely causing the rough idle.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  3. #3 Re: Rough Idle
    USA
    Wow I thought to check and someone had just posted. Thanks man I'll let you know how it goes. How's that GP running with 227K miles?
  4. #4 Re: Rough Idle
    Could also be the CPS if that doesn't fix it.
  5. #5 Re: Rough Idle
    USA
    Googling CPS turned up 'central power supply'. Is this what you mean? Obviously I'm learning so could you explain what this is and why it could be causing a rough idle? I couldn't find a whole lot initially.
    Thanks!
  6. #6 Re: Rough Idle
    Michigan
    Runs great. Oil is not even dark when it's changed. Planning on 400,000 miles plus depending on how the body holds up. At the GMPT Factory 36 reunion (where the 3800's were made) the winner had 450,000+ miles on his motor with no re-build. 200,000 miles was actually rather common.
    The secret is that tolerances were ran "tight" during the manufacturering process and every motor was "hot tested" before being shipped. That way if there was a problem it was caught before it left the factory.
    '02 Bright Red GT
  7. #7 Re: Rough Idle
    USA
    Quote Originally Posted by mystic231 View Post
    Yea they are great engines. Only thing to go wrong with mine since I got it 55,000 miles ago was the lower coolent intake gasket. Everything else is just regular maintenance or small, like this IAC.
    Speaking of that I'm looking around and not finding a place to buy the part. I've looked on Napa's website and can't find anything relating to intake. Maybe I'm blind, but if someone finds a site, could you post it.
    Thanks.
  8. #8 Re: Rough Idle
    USA
    Well I've found these. I'm assuming one of these would work. Any comments on these? I won't order quite yet.
    RockAuto Parts Catalog
  9. #9 Re: Rough Idle
    Michigan
    Any one of those would work fine.
    '02 Bright Red GT
  10. #10 Re: Rough Idle
    USA
    Awesome. I'll probably order it in a couple weeks. Gotta finish up my internship and get home where I have a place and tools to do it.
    I'll probably write up a little how-to about it as well, so anyone looking for a rough-idle solution can find it. There seem to be quite a few about...
  11. #11 Re: Rough Idle
    CPS is the crank positioning sensor.
  1. minor rough idle prob
    By sideshow elvis in forum General Tech Discussion
    Last Post: 07-28-2009, 05:09 AM
  2. '97 GTP, rough idle
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 01:14 AM
  3. Almost rough idle
    By DesQ27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2009, 08:31 PM
  4. Rough/hunting idle
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2008, 11:22 PM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
