Thread: Cold Air Intake Help!
Results 1 to 19 of 19
  1. #1 Cold Air Intake Help!
    Kalamazoo, Michigan
    2005 Grand Prix 3800 Non Supercharged. I am looking for a cold air intake. I know many people reccomend using the box style set up and building one but what about a cold air intake such as this: Air Intake Pontiac Grand Prix GT GTP V6 2004 2005 2006:eBay Motors (item 350217425925 end time Jul-23-09 21:48:31 PDT) do that actually work? Are they worth it? Thanks!
  2. #2 Re: Cold Air Intake Help!
    Norristown, PA
    You get what you pay for, i suggest you make your own fwi
  3. #3 Re: Cold Air Intake Help!
    trash...build your own.
  4. #4 Re: Cold Air Intake Help!
  5. #5 Re: Cold Air Intake Help!
    Quote Originally Posted by bio248 View Post
    im not even going to repeat the statement.
    doooooooooooooo iiiiiiiiiiiiiiiiiiiiiiiiiiiit
  6. #6 Re: Cold Air Intake Help!
    no, ill skip the "make your own" and say this:
    the box doesnt really keep the air any cooler than any good PVC or aluminum intake would. just get it close to the fender and call it a day.
  7. #7 Re: Cold Air Intake Help!
    GT Level Member Will5600's Avatar
    subs of chicago
    Make your own
    1. take your air box out the car
    2. get a filter what ever knn is good
    3. get a 3'' diameter 90 deg rubber bend connect to air filter
    4. get a 3" diameter 60 deg pvc bend connect to 90 deg
    5. get and 3'' diameter pipe find out the length u need and connect to 60 deg and to coupling
    6. then get a coupling to put it on the intake
    7. the air filter will go in your wheel well
  8. #8 Re: Cold Air Intake Help!
    Quote Originally Posted by Will5600 View Post
    Make your own
    should have gone with 4". seriously.
  9. #9 Re: Cold Air Intake Help!
    What did I say that one day about intake size...something about a choking a fat chick on cholesterol? LOL
    The bigger the pipe the better these cars run. 3" is weak. Go 4"
  10. #10 Re: Cold Air Intake Help!
    subs of chicago
    dude that is what it is and its all good would have like to know this before its still nice
  11. #11 Re: Cold Air Intake Help!
    Kalamazoo, Michigan
    Make your own
    This wont work on an '05 will it?
  12. #12 Re: Cold Air Intake Help!
    No...you would just have to cut the pipe in half to fit the MAF in there.
  13. #13 Re: Cold Air Intake Help!
    SE Level Member Traeger2591's Avatar
    IL
    how much of a difference is there between the 3" and 4" I really want to do the 4" cause everyone says its better, but I don't want to have to cut stuff up and whatnot.
  14. #14 Re: Cold Air Intake Help!
    TDCRacing
    Guest
    If you don't want to cut stuff up and want a nice intake check ours out. They are the cheapest most well designed intake out there. We just added the LQ4 models and the 04+ models to the site tonight.
    Welcome To TDC Racing
  15. #15 Re: Cold Air Intake Help!
    IL
    I've actually looked at that a few times because everyone says it's the best one to buy if you buy one, but I'd rather make my own than spend alot of money on one. Just wondering but what size is your fwi? And I'm still interested in how much of a performance difference there will be b/t 3" and 4". Thanks.
  16. #16 Re: Cold Air Intake Help!
    TDCRacing
    Guest
    No problem,
    Our FWI is constructed out of 4'' manderal bent tube. And it all depends on where your at in a performance standpoint if your going to need a 4'' over a 3''. I would just go with a 4'' and not worry again about it.
  17. #17 Re: Cold Air Intake Help!
    IL
    Ok thanks for the help. I'll be happy with any boost in performance as far as I'm concerned haha.
  18. #18 Re: Cold Air Intake Help!
    Minnesota
    Will that work on a 2000 gt?
  19. #19 Re: Cold Air Intake Help!
    Quote Originally Posted by HumanWeapon View Post
    TDC Racing's Fenderwell intake? Sure...go buy it from him...I'm sure others will chime in...
  1. looking for a cold air intake
    By hockey8599 in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 04:23 PM
  2. cold air intake?
    By hodge in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2009, 03:48 PM
  3. Cold air intake
    By redrunner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2008, 09:52 PM
  4. K&N Cold Air Intake
    By reallyfast1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2008, 07:39 AM
