I'm pretty sure my MAF sensor is bad. When I first start up my car put it in gear and hit the gas pedal the rpms drop and the engine studders. It sometimes cut off when I hit the go pedal. When the car it warm it doesn't do this. I did a test, when the car was cool I started the car and lightly hit the maf sensor with a screwdriver handle. The rpm's started to go up and down when I did this. I have been looking at the maf sensor prices and the zzp maf conversion (this kit ZZ Performance) is a little cheaper than the factory sensor. Is this kit better than the factory sensor? Should I get the kit? My L36 engine is otherwise stock. There will be more mods in the future though.
