Thread: Question On Air Fuel Ration Guage Instillation
Results 1 to 15 of 15
  1. #1 Question On Air Fuel Ration Guage Instillation
    Apr 2009
    Hartford, WI
    I need help installing this guage in my car! I have the wiring ran and I also bough the pigtail for my car to install this meter but I cannot find out where it goes if you have any info on this matter please PM me back it would be greatly appreciated. I have a 1999 Pontiac grand Prix GT.
    1999 Grand Prix GT-Cold Air kit. PCM Chipped, Auto Meter Gauges with Lotek 2 pod Pillar, Dual Flowmaster exhaust from the cat back U-bend Delete
  2. #2 Re: Question On Air Fuel Ration Guage Instillation
    GT Level Member pontiackid's Avatar
    KCMO
    IIRC the Air/Fuel ratio gauge...
    the pigtail should be going to the/a 02 (oxygen) sensor.
    on the Grand Prix's there are 2 Oxygen sensors.
    1. Located directy on the rear header right before where she bolts to the downpipe. (sticks straight up, ontop of pipe) Right next to the rear spark plug towards the drivers side.
    2. Located back after the downpipe above the "U bend" adjacent to the catilayc convereter
    -KT
  3. #3 Re: Question On Air Fuel Ration Guage Instillation
    Apr 2009
    Hartford, WI
    Which one would you prefer that it be plugged into? Or does it not
    matter? Thank you very much for the info!
  4. #4 Re: Question On Air Fuel Ration Guage Instillation
    Barksdale AFB, LA
    It needs to be plugged in to the one in the rear manifold.
    Enjoy the light show.
    2009 Subaru Impreza WRX STI
  5. #5 Re: Question On Air Fuel Ration Guage Instillation
    Apr 2009
    Hartford, WI
    Thank you for both inputs I appreciate it and it was exactly what I needed to know thanks again!
  6. #6 Re: Question On Air Fuel Ration Guage Instillation
    May 2008
    staten island,NY
    i hope its a wideband, otherwise you wasted money
  7. #7 Re: Question On Air Fuel Ration Guage Instillation
    Barksdale AFB, LA
    Quote Originally Posted by QwikGT View Post
    You don't use a pig tail to install a wideband...
  8. #8 Re: Question On Air Fuel Ration Guage Instillation
    Apr 2009
    Hartford, WI
    Yes it is the wideband gauge! I was told that I needed this pigtail to install it so I am not splicing into factory wires incase I want to resell the car.
  9. #9 Re: Question On Air Fuel Ration Guage Instillation
    Barksdale AFB, LA
    If it's a wideband, you don't connect it to any existing sensors. You have to add your own. The stock sensors are narrow bands.
  10. #10 Re: Question On Air Fuel Ration Guage Instillation
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    is it possible to swap one of the nb out and put in a wb (but not hook it to harness, use a fake out sensor) and hook up to a gauge? but still leave the aft sensor still plugged up?
  11. #11 Re: Question On Air Fuel Ration Guage Instillation
    Jan 2009
    san diego
    ttt...i think this would work, but is it worth it? i might to top swap later..or hybrid the swap and turbo it instead of s/c...but i couldnt use my fwi from tdc if i did that...dang!!
  12. #12 Re: Question On Air Fuel Ration Guage Instillation
    taking out the front o2 sensor will make your car run like utter crap. have fun with that.
    you need to weld in another bung. do i need to go take a picture of my exhaust for you?
  13. #13 Re: Question On Air Fuel Ration Guage Instillation
    Jan 2009
    san diego
    sure. so three sensors in there, would be awesome. i was thinking about a top swap, would be nice to have teh wb to see whats goin on, i guess i could weld in another if i do end up with u bend delete, wouldnt take long, could get guys at work to do it for me.
  14. #14 Re: Question On Air Fuel Ration Guage Instillation
    you have to weld in the wideband sensor before the cat.
    the ubend is too far back.
  15. #15 Re: Question On Air Fuel Ration Guage Instillation
    Jan 2009
    san diego
    are these good? i think they would be pretty good, especially for the price. looks like they have the bungs welded in already too. probably be able to run the 3.25 pulley on these too.
    eBay
  1. 1999 Grand Prix fuel guage not reading?
    By lucky chucky in forum General Tech Discussion
    Last Post: 04-21-2009, 01:34 AM
  2. Fuel pressure guage question?
    By basshead42 in forum General Tech Discussion
    Last Post: 03-27-2009, 12:36 AM
  3. Fuel Filter question
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 03-26-2009, 09:20 PM
  4. interceptor guage question
    By Risinnfallen in forum General Tech Discussion
    Last Post: 08-15-2008, 06:36 PM
  5. fuel pressure question
    By jdevier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2008, 11:35 AM
