Thread: Only a 3" FWI
Results 1 to 8 of 8
  1. #1 Only a 3" FWI
    SE Level Member Aceoage's Avatar
    Jul 2008
    Saskatchewan, Canada
    I ordered a 3" filter thinking it would be big enough, how much of a difference is there between a 4" FWI and a 3" FWI on a GT? Is it worth sending back or is the gain negligible?
    For what it's worth, I also have an L67 TB and will be using heat wrapped exhaust pipe.
  2. #2 Re: Only a 3" FWI
    You can do 3"...its fine...it just doesn't perform as GOOD as the 4", but it will work. Just wrap the exhaust crossover...and for the TB...do you have a tuner? If not then it won't work too well...honestly I would be surprised if it started and ran normal.
  3. #3 Re: Only a 3" FWI
    Jul 2008
    Yes I've a tuned PCM from Overkill programed for the new TB in the car already, which is giving me minor inconveniences until I fit the new TB.
    Would it be worth taking my filter back for the performance gains?
  4. #4 Re: Only a 3" FWI
    Quote Originally Posted by Aceoage View Post
    It would probably be worth putting the THROTTLE BODY your car is tuned for man...
  5. #5 Re: Only a 3" FWI
    Jul 2008
    I know, I put the PCM in right away because I had no torx bits but I did have the proper wrenches to put the bolts into the PCM. Tomorrow I will get that installed and get some exhaust pipe bent, this filter ought to do for a GT.
  6. #6 Re: Only a 3" FWI
    Donating Users mystic231's Avatar
    Michigan
    Have you changed the downpipe yet?
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  7. #7 Re: Only a 3" FWI
    Jul 2008
    No, The only real performance mods I have are a ubent delete, a PCM, and now this new intake.
  8. #8 Re: Only a 3" FWI
    It's a GT, so a downpipe isn't as great of a mod as it is on a GTP. Sure, get a 2.5" Catted Downpipe, Front Powerlog Manifold...then get your TB installed and HV3 Upper Insert...should run 14's with a good launch in cooler weather IMO.
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. "Inferno Appearance" or 06 "SE Appearance Package"
    By romande in forum Visual/Body Modifications
    Last Post: 04-02-2011, 12:56 PM
  3. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
