Thread: disappearing oil
Results 1 to 5 of 5
  1. #1 disappearing oil
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    hello. at the beginning of the year i had my rear main seal plate gasket replaced. before that it leaked ALOT of oil. since then, the engine holds oil fine until it gets about 2500 miles into an oil change. its fine once i change the oil, then after about 23-2500 miles the oil level on the dipstick starts going down. it goes from full to down the the add line in just a few hundred miles. ONLY when its about time for an oil change. i use valvoline conventional 10w30 with an ac delco filter. there are absolutely no oil marks underneath where i park it. none.
    im open to any thoughts/suggestions.....
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  2. #2 Re: disappearing oil
  3. #3 Re: disappearing oil
    Nov 2008
    Fremont Nebraska
    nope, the coolant looks fine
  4. #4 Re: disappearing oil
    you burning it? exhaust gets grey/blue colored when you mash on it?
  5. #5 Re: disappearing oil
    Nov 2008
    Fremont Nebraska
    i dont think so..... i havent noticed but will now keep an eye out
  1. disappearing doors
    By crashman in forum Off Topic Discussion
    Last Post: 08-01-2008, 07:13 AM
