i took the wifes 2000 gp/gt up to a-zone and had the codes read and it came back....
bb1- vac hose off, cracked, passage blocked
bb2- throttle body intake tube loose, off, or cracked
bb3 BARO/MAP defective
bb4 VAF/MAF sensor dirty or defective
i went out and checked all connections and everything is tight and didnt see or hear any vac leaks. I took some carb cleaner and sprayed in the TB, the accel. pedal would stick so im sure it was dirty and its not sticking anymore.
Is there a way to reset the CEL to see if i got it fixed or not or what should i do ??
