Thread: Need more input for stock 3.8 NA
Results 1 to 15 of 15
  1. #1 Need more input for stock 3.8 NA
    Louisville, KY
    We need a lot of input in this section, maybe put together a post on how to make my NA faster or well have 20 new post a week posted on the same topic.
    Elk Grove Village, IL
    I used to have a FAQ I wrote way back when when I had my GT. Ill try to find it.
    GT Level Member flynn's Avatar
    Overland Park/Topeka, KS
    THANK YOU!!!
    I always get **** from my local club about doing mods to my GT, like taking off the speed limiter.
    Signatures suck!
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by flynn View Post
    THANK YOU!!!
    Since when?
    Odessa, MO
    THANK YOU!!!
    You do? Never saw that I guess. I don't recall the last post you even made about modding it. You must not be talking about KCPMC.
    I live here. UR LOSN's Avatar
    Rockford, IL
    1.9 rockers, LS6 springs, tune, CAI, 3" DP, PEM's, and a sticky tire.
    this should be pretty potent for N/A. and if you have time go for a cam/spray.
    SE Level Member Coogles's Avatar
    Quote Originally Posted by UR LOSN View Post
    Yep, although I'd change the 1.9's to the ER Ratio that ZZP sells. If you're running FWD then the HV3 is a sound investment also.
    Forest Green 1998 GTP Sedan - SOLD
    VS, 3.2, TOG, GMPP Suspension, 3EP Tune
    13.179 @ 106.57 w/2.005 60'
    Rockford, IL
    good point!!^^^^^
    Quote Originally Posted by Abrasive View Post
    Sorry guys. Sounded different in my head than it did when I was typing it..
    I take back what I said earlier and offer to wear a "Dunce" hat for my stupidity.
    Signatures suck!
    Rockford, IL
    pics^^^^^^^^^^
    SE Level Member SDGrandPrixGT23's Avatar
    San Diego, California
    Im new to this forum. Thought I would throw my 2 cents about modding N/A's, since I still have a N/A GP.
    Ive got the stupidly exspensive K&N FIPK air intake, DHP 1.0 PCM, Comp Cams Xtreme Energy L36 Cam 2, Comp Cams Pro Magnum Hydraulic Lifters, Comp Cams High Load Valvesprings, Comp Cams Hi-Tech Pushrods, 1.80:1 High Ratio Modified Rocker Arms, 3" DP w/ Cat, Flowmaster Exhaust *workin on headers* so basically i bought off of 3800performance.com
    So what do you run, after spending all of that money?
    Signatures suck!
    A cam and 1.8 rockers?? Better be sure you can run those with the cam. Otherwise I see a L67 swap in your future cause your gonna damage something.
    Ive got the top end swap in mind, just havent decided on lookin for a GEN V or settling for a GEN III
    My car is still a virgin to the track and dyno's. Im in the Navy w/ tons of money and they recently closed LACR so I just have fun out on streets
