Thread: CEL "on"
Results 1 to 3 of 3
  1. #1 CEL "on"
    Nov 2008
    Indiana
    i took the wifes 2000 gp/gt up to a-zone and had the codes read and it came back....
    bb1- vac hose off, cracked, passage blocked
    bb2- throttle body intake tube loose, off, or cracked
    bb3 BARO/MAP defective
    bb4 VAF/MAF sensor dirty or defective
    i went out and checked all connections and everything is tight and didnt see or hear any vac leaks. I took some carb cleaner and sprayed in the TB, the accel. pedal would stick so im sure it was dirty and its not sticking anymore.
    Is there a way to reset the CEL to see if i got it fixed or not or what should i do ??
  2. #2 Re: CEL "on"
    GTP Level Member Scimmia's Avatar
    QCA, IA
    First off, we need actual codes, not descriptions.
    Easiest way to reset the light is to disconnect the battery for a couple of hours. Autozone may or may not do it for you, too.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: CEL "on"
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    autozone will clear them if you tell them to, although they dont like to. i left my batterty disconnected overnight once and it still didnt reset the CEL, i also tried pulling the PCM fuses once to no avail, the only thing thats ever worked for me is the code reader, or time (once the problem is fixed)
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. "Inferno Appearance" or 06 "SE Appearance Package"
    By romande in forum Visual/Body Modifications
    Last Post: 04-02-2011, 12:56 PM
  3. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
cel
