Thread: Which oil filter?
Results 1 to 20 of 32
  1. #1 Which oil filter?
    SE Level Member Pontiacman's Avatar
    Amarillo, Texas
    Hey guys how is it going? Rightnow I am using a ac delco oil filter and was wanting to try another brand. I have been reading up on the K&N oil filter and the M1 filter. I have read a few things on the WIX filters and a lot of people like them. Should I just stick with ac delco or try something else?
  2. #2 Re: Which oil filter?
    Jersey
    I use either acdelco, or if i want to splurge i get the mobile 1
    16' wrx sti- stock
  3. #3 Re: Which oil filter?
    Donating Users RedLedbetter's Avatar
    Feb 2009
    Illinois
    Quote Originally Posted by 99prixgt View Post
    ^^X2
    ive never used the K&N but i might try it out my next oil change
    SPREAD THE JAM
  4. #4 Re: Which oil filter?
    chicago
    ac delco or mobile 1 are what i used
  5. #5 Re: Which oil filter?
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    acdelco if I dont stop at the shop before I take it in, if I stop its only WIX.
    Its the only two ive ever used, including tranny filters.
  6. #6 Re: Which oil filter?
    Aug 2008
    60118 NE Illinois
    I am still skeptical on the K&N oil filters..
    there are only a couple filter manufacturers, acdelco are private label wix filters.
    the worst filters to use all around are fram, I think if you stay way from fram you should be ok.
  7. #7 Re: Which oil filter?
    chicago
    i used fram on my hunduh but i'm going to start using purator my next oil change
  8. #8 Re: Which oil filter?
    Aug 2008
    60118 NE Illinois
    Its a wonder how fram filters. i used to use em years and years ago on my sbc astrovan had I used even a stocker that engine would still be alive.
  9. #9 Re: Which oil filter?
    Barksdale AFB, LA
    I've used ACDelco, STP, K&N, Amsoil, and Wix. All good. If someone tries to sell you a Fram, take it from them and crush it against the side of their head.
    2009 Subaru Impreza WRX STI
  10. #10 Re: Which oil filter?
    Dec 2008
    Lawndale, CA
    I stick with the delco here. I have used K&N and mobil 1 as well. I used the mobil 1 when autozone had a deal going on when buying mobil 1 oil and getting the filter free.
  11. #11 Re: Which oil filter?
    Jersey
    Quote Originally Posted by Sabrewings View Post
    lol autozone guy tried more than once, I think I will smash it on his head next time.
    16' wrx sti- stock
  12. #12 Re: Which oil filter?
    SE Level Member beast3300's Avatar
    lmao, X2
    Black 98 Regal GS: best run 13.95@99.75
    99 Red GP L36: 15.5 in 1/4
  13. #13 Re: Which oil filter?
    Oklahoma
    As flimsily as they are made, that should not be hard to do.
  14. #14 Re: Which oil filter?
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    I use mobil 1 extended, my next oil change I'm going to use Napa gold on the advice of Overkill. On powerblock tv they showed some rp oil filters, I may try them since I use their oil.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  15. #15 Re: Which oil filter?
    Aug 2008
    Long Island, New York
    Royal purple makes good filters, WIX, and K&N
  16. #16 Re: Which oil filter?
    i use fram because im cheap and i dont care if i destroy the block i have in the car right now.
  17. #17 Re: Which oil filter?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Then use a WalMart SuperTech filter. It is cheaper, and a much better filter.
    I tend to run a Mobile 1 filter on the GTP. The M102 has a slightly larger capacity, too.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  18. #18 Re: Which oil filter?
    Oklahoma
    Quote Originally Posted by JoshMcMadMac View Post
    Not to pick a fight or anything, Im just curious to such statements and what criteria you use to qualify that statement? I mean, how are you determining it is a much better filter?
  19. #19 Re: Which oil filter?
    Waynesboro, PA
    Talking with a lubrication engineer with 40+ years of experience. SuperTech is by far the best bang-for-the-buck.
  20. #20 Re: Which oil filter?
    Amarillo, Texas
    I am trying RP in my car and for what I paid for it I want to get the most out of the oil. Every car I have owned I have used AC Delco and never had eny trouble with it. I don't know how many miles I could go on the filter. I just want something that will go at least 6k miles. Will the ac delco last that long?
  1. what filter is best?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2009, 11:50 PM
  2. S.O.B. Fuel Filter
    By quiksilvergt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2008, 01:16 PM
  3. What K&N Air Filter To Use
    By SG2000GTP in forum General Tech Discussion
    Last Post: 06-01-2008, 06:00 PM
  4. Anyone have an S&B filter?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 04-12-2008, 07:18 AM
