Thread: How similar are the stock 99 t/b's vs. pre 98's
Results 1 to 7 of 7
  1. #1 How similar are the stock 99 t/b's vs. pre 98's
    Jersey
    Just curious how similar they are, from what i understand they are the same bore, just the 99 has slightly better flowing walls? correct me if im wrong. Basically im trying to sell my overkill pcm and the question pop't up as to whether or not the pcm would work on a 98' since the t/b's are different for the years.
    16' wrx sti- stock
  2. #2 Re: How similar are the stock 99 t/b's vs. pre 98's
    Hoffman/Schaumburg, IL
    The 97-98 have a huge aluminum piece in the middle for the different maf sensor, the 99+ don't have that, and have th newer maf sensor..... I would say no to using a PCM for a 97-98 on a 99+.....It might not cause any problems, but the fuel trims would def. be off
  3. #3 Re: How similar are the stock 99 t/b's vs. pre 98's
    GTP Level Member Scimmia's Avatar
    QCA, IA
    The MAF calibration is definitely different, not interchangeable
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: How similar are the stock 99 t/b's vs. pre 98's
    if you want a sweet hogged out throttle body definitely start with a 97/98. youll have less chance of breaking through and you can physically make it bigger.
  5. #5 Re: How similar are the stock 99 t/b's vs. pre 98's
    Jersey
    Thanks guys, it looks like this pcm will be harder to sell than i thought.
    16' wrx sti- stock
  6. #6 Re: How similar are the stock 99 t/b's vs. pre 98's
    Jersey
    The bracket's are the same on the throttle bodies? Could someone with a pre 99' t/b upgrade to a 99 style t/b and maf by just simply replacing it? granted there would be tuning changes needed.
    16' wrx sti- stock
  7. #7 Re: How similar are the stock 99 t/b's vs. pre 98's
    QCA, IA
    Yes, they have the same bolt pattern and will physically swap just fine, you would just need to tune the MAF.
  1. Stock stereo backlight inop? Which speakers to replace stock?
    By Z28 in forum Audio, Security & Visual Electronics
    Last Post: 12-04-2008, 11:47 PM
  2. Stock HU going bye bye
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-01-2008, 06:22 PM
  3. 235/45/17/ or stock 225/45/17
    By 04CompG in forum Tires & Wheels
    Last Post: 05-23-2008, 11:36 AM
