hi all wanted to see if anyone else has tried this so i searched a lot found nothing like ti thought id just ask. I had a wizzard style box before with a heat shield and 3" pvc. now i upgraded to 4 inch and i was trying to see about making a fwi but after looking around in the lesabre i found that the evap canister is the exact size as the filter. so i moved it to a new local(tbd) abd ran the 4" piping to the hole with only a 45 out of the throttle body then a straight piece then a sweep 90 then the filter sticking out the bottom its literally sitting right behind the bumper cant be much colder air than that. anyways just seeing if the grand's were the same way and if anyone has tried it? if not the Bonneville? oh and still working on a good spot for the ecu also there both quazi mounted but anyways thoughts?
