Thread: another ticking question
Results 1 to 3 of 3
  1. #1 another ticking question
    Feb 2009
    kitchener ontario canada
    my 2002 gtp has had a ticking nosie when its cold and a miss on #4 at the same time ...the intake gaskets are leaking to the rad has oil in it also so now today when its warm the noise dosent go away and it throws a code into it..i checked commpresion 150 psi
    checked everything and it all seems fine
    lifter?
    or due to the intake gaskets do you guys think thats messing it up
    or head gasket
    thanks
  2. #2 Re: another ticking question
    do your lower intake gaskets and check the lifters when youre down there. could be a loose rocker too.
  3. #3 Re: another ticking question
    Feb 2009
    so i took it all apart last night and it had 3 collapsed lifters so i replaced them all and put it all back together and it runs better than it has in a long time
  1. DP ticking
    Last Post: 03-01-2009, 11:39 PM
  2. Ticking noise, thinking lifter
    By bradford82 in forum General Tech Discussion
    Last Post: 01-25-2009, 10:44 AM
  3. Ticking
    By theboss98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2009, 01:17 PM
  4. i need help! engine ticking?? 3800
    By a.caldwell11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 03:45 PM
  5. ticking noise???????
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 10-02-2008, 12:27 PM
