Thread: L36 Swap Questions
Results 1 to 3 of 3
  1. #1 L36 Swap Questions
    SE Level Member VGPGT's Avatar
    Hammond, WI
    L36 Swap Questions.
    I have pulled my 3800 out of my 1997 Grand Prix. I am swapping parts from it to the replacment 3800 which came out of a Monte Carlo.
    The heater hose connectors are arranged a little different. It looks like I can pull off or pull out the ends that actually hooks onto the hose and swap them. Or is it easier to swap the whole assembly which may include the tensioner pulley.
    Also the oil filter on my new engine sits at an angle compaired to the engine I pulled. I am wondering if I need to swap this also?
  2. #2 Re: L36 Swap Questions
    SE Level Member a97GTP's Avatar
    Jul 2013
    Priest River, Idaho
    i would Swap the Oil Filter Extension Arm for sure Just to be safe there are Clearance Issues and For the Heater Hose connector Just swapping the Ends should work just fine
    Black 1997 Pontiac Grand Prix GTP, 3.4" Pulley, P&P Supercharger, Modified LIM, VS-Cam, 105# Springs, FWI, Ported Rear Manifold, ZZP P-LOG, EGR Delete.
    ^^^L36 Top Swap^^^ R.I.P. L67 197,894
  3. #3 Re: L36 Swap Questions
    Quote Originally Posted by VGPGT View Post
    L36 Swap Questions.
    I typically do the whole tensioner bracket assembly. That way you put in fresh coolant elbows and know you are good.
    Quote Originally Posted by a97GTP View Post
    No need for the oil filter adapter, it's W body to W body. Same part number.
  1. A ton if Questions for my upcoming top swap
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 01:36 AM
  2. General Gen. V blower swap questions
    By GTPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2009, 06:38 PM
  3. Got some questions about the top swap??
    By biggmman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 06:24 PM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    Last Post: 02-07-2008, 08:49 PM
