Thread: power steering pump question
Results 1 to 3 of 3
  1. #1 power steering pump question
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    Im pretty sure that im low on fluid because when i turn a sharp corner it starts to wine and then wont stop and by it sounds its either that or a tensioner so i figured i would stop here. i was just wondering if you could overfill the resevoir and cause damage to the pump? also what is the best way to bleed the lines on these. Ps finding the opening on the resevoir took me about 45 min couldnt they have put a yellow cap on there jeeze
  2. #2 Re: power steering pump question
    TDCRacing
    Guest
    No. Over filling may can not cause damage to the pump. But may cause overflowing when the fluid get's hot.
    If it's only when you turn then it is not an idler pulley.
  3. #3 Re: power steering pump question
    Nov 2008
    I got her all figured out i just hope that i dont have to bad of a leak. thanks alot for the help come to find out there is a lable on top of the cap but the engine bay in my car looks like it hasnt been cleaned since the car was built. that will be my next project after i get the paint cleaned up
  1. Power Steering Pump Replacement [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 05-11-2013, 03:28 PM
  2. Power steering pump noise
    By minichopper6hp in forum General Tech Discussion
    Last Post: 07-18-2009, 01:57 AM
  3. Power steering pump mystery
    By cidknee in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:50 PM
  4. Power Steering pump
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2008, 07:16 AM
  5. belt help, bypassing power steering pump
    By skates in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2008, 11:24 AM
