Thread: P0107 After Valve Cover Gasket repairs
Results 1 to 2 of 2
  1. #1 P0107 After Valve Cover Gasket repairs
    Jan 2024
    Pennsylvania
    Hello All,
    First and foremost, I am AWFUL with electronics on cars BUT I recently did the valve cover gaskets for inspection. Now I have this wonderful code on. Where exactly IS this sensor at? Is it near the back where I'd need to remove stuff to get that rear cover off? Cause if so, I MAY have solved this already cause I dumbed and missed connecting something back there but I honestly have zero idea if that was actually it. The part that was left out was a white 3-pronged connector if that's helpful to the pros.
    Thanks!
  2. #2 Re: P0107 After Valve Cover Gasket repairs
    St. Louis
    IIRC, the P0107 code is related to low voltage to the MAP sensor. Below is a pic of it where it lives on the upper intake manifold:
    They are often fragile and the top can separate from the body if smacked while moving things around to get to the rear cover. If this is the case then get a new one. Also verify that the wiring to it is good.
    Other than that the only plugs I can think of back there are for the upstream 02 sensor and some California emissions stuff that you likely don't have (this one stays unplugged).
    P0107 After Valve Cover Gasket repairs Attached Images
  1. '04 Valve Cover Gasket DIY
    By robinsone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-15-2015, 01:55 PM
  2. valve cover gasket
    By kawasakidrivinghick in forum General Tech Discussion
    Last Post: 02-22-2013, 04:59 PM
  3. Valve cover gasket
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2011, 05:11 PM
  4. Valve cover gasket
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 10:25 PM
  5. valve cover gasket
    By BFish in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-12-2008, 03:51 PM
