Alright. So a few months ago, I bought a 2000 2dr Grand prix gt coupe. Originally what I noticed it was brakes all the way around, front struts (springs to be exact) were broken in half and the fuel gauge didn't work properly. Well I took it to a good friend of mine who is a damn good mechanic and he told me what else was wrong with it which mainly involved the motor itself...
This past week I spent over $500 on just parts; radiator, spark plugs, plug wires, lower radiator hose, vacuum line harness and all 3 ignition coils; due to a MASSIVE coolant leak, misfire and the harness being split and or torn at every rubber adapter pieces.. I'm still having issues with the her.. the rpms run high when driving, when I go to press the brake the right front squeaks really bad, and also when I brake the rpms drop from 2000 to in between 700-900 sometimes lower then go back up...
I've replaced the front brakes and rotors along with the strut assemblies. I know there is a code about the mass air flow low circuit (something along the lines of not getting enough voltage to it) but I wouldn't think it would cause that much difference in rpms and what not..
I paid $1800 for the car and I'm not sure if I should continue throwing money into it or if it's time to get ride of her. She has roughly 250k already
Total amount replaced: $1198
Total amount left to fix: $ 1179
