Thread: Fuel pump replacement as preventative maintenance
Results 1 to 3 of 3
  1. #1 Fuel pump replacement as preventative maintenance
    Aug 2021
    Brownsville
    Hello everyone,
    I have a 2001 Pontiac grand prix with 117000 miles, showing a code P0446, which I believe is due to the fuel tank pressure sensor since I already changed the purge canister. My question is, since my car is 20 years old, the fuel tank pressure comes with fuel pump assembly, do you guys think it a good idea to replace the whole thing instead of just the sensor?
  2. #2 Re: Fuel pump replacement as preventative maintenance
    St. Louis
    If it's working I'd leave it alone. Also check the vacuum lines to the canister as it can cause that code too. Just hang onto the new fuel pump for future use.
  3. #3 Re: Fuel pump replacement as preventative maintenance
    Oct 2014
    portland oregon
    When I changed my canister due to the code, I still got the code. I was pissed off.
    During my wtf investigation, I discovered charcoal from the canister had made its way up to the purge solenoid.
    By taking the time to clean it out (air hose with a blower tip), it shot out enough coal to have a BBQ. Cleared the code it hasn't returned.
    Sent from my SM-G981V using Tapatalk
  1. Fuel Pump replacement E85
    By rickisrad in forum General Grand Prix Discussion
    Last Post: 02-27-2017, 07:13 PM
  2. New 2007 GP - Preventative Maintenance?
    By TuKoolGTP in forum General Grand Prix Discussion
    Last Post: 01-01-2017, 08:23 PM
  3. 04 Fuel pump replacement
    By ADrugDealer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2013, 01:16 PM
  4. Preventative maintenance
    By firstgtp in forum Introductions/Noob Questions
    Last Post: 09-03-2013, 08:25 AM
  5. Routine/preventative maintenance
    By Cartune in forum General Grand Prix Discussion
    Last Post: 08-17-2012, 01:55 PM
