Thread: Starter engaging while driving
Results 1 to 3 of 3
  1. #1 Starter engaging while driving
    Dec 2019
    US
    Ok so ONLY when it's raining my starter will engage while I'm driving sometimes briefly other times it won't stop until I kill the car. I thought the solenoid may have just gotten super wet and was shorting out but changed out the starter and still doing the same thing. No matter what gear the car is in it still engages. Has anyone had anything like this before?
    Sent from my moto g(7) supra using Tapatalk
  2. #2 Re: Starter engaging while driving
    May 2020
    Pittsburgh
    You definitely have a short on the starter circuit. Follow a diagram to where it gets signal from, and follow there. I don't have a diagram on hand but someone on here might, Or a Haynes/Chilton manual will for sure.
    There should be two wires on the starter, it'll be on the smaller wire. It's shorting to power somewhere.
  3. #3 Re: Starter engaging while driving
    HUDSON
    First, if your car should not "crank" while the shifter is in any selection other than"P" or "N", check the neutral safety switch and wiring, or something is energising the "PPL" wire after the "N:" switch, or something is wrong with the "PPL" wire from the "N" switch to the starter.
    I gather from your description of the fault, switched 12V power is engaging your starter solenoid, I say it is "switched" because you state it stops when you shut the car off.
    1) check for installed aftermarket remote start hardware faults
    2) check for installed aftermarket alarm system hardware faults
    3) Check for general buggery.
    4) I only have wiring diagram for 98-02, other years could be different.
  1. Starter engaging while driving
    By tiffanyfontenot99 in forum General Tech Issues
    Last Post: 04-16-2021, 10:32 AM
  2. Starter ebgages in rain while driving
    By tiffanyfontenot99 in forum General Tech Discussion
    Last Post: 04-16-2021, 10:31 AM
  3. Transmission not engaging?
    By Bcriswell810 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-20-2016, 02:27 PM
  4. A/C not engaging
    By MattGTP04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2015, 11:58 AM
  5. Keep stock starter set up and add 4 gauge hot wire to starter
    By Jason97GrandprixGT in forum Audio, Security & Visual Electronics
    Last Post: 04-08-2015, 08:21 AM
