Thread: 2007 GP randomly dies
Results 1 to 3 of 3
  1. #1 2007 GP randomly dies
    Jan 2021
    US
    Have an 07 3800 na that will randomly die idling or driving. I know before I bought the car that the previous owner replaced the crank sensor. Since the fall the car will randomly just die and seems to be more frequent now. No codes but the info display will read "starting disabled due to electronic throttle control". I've plugged in my Bosch code reader and my blue tooth odb and checked live reading of the throttle body and really not seeing anything odd. Once it dies it takes 30 seconds or so before it will crank and start, before then turning the key does nothing. I took the TB off and cleaned it, sprayed electronic cleaner in the TB connector, MAP plug and MAF plug. Starts alot better than it used to but still dies randomly. Cold start has never been an issue. Before I throw parts at it I am wondering if because if the display it is simply the throttle body sensors. Car has 245k and no cel light on. Been reading as much as I can but do not recall anything where this comes up on the display, at least I don't remember. One other thing remote start does not seem to work anymore...coincidence?
    Thanks
    Sent from my SM-G973U using Tapatalk
  2. #2 Re: 2007 GP randomly dies
    hangover park IL
    more than a dozen times ive come across this sort of under high load stalling/stutering/stalling is related to the harness being improperly routed/secured and shorting out omn the ac compressor pulley/back of crank pulley/etc.
    always start with the most recent repairs and verify nothing went wrong before guessing on causes, most likely a portion of the ICM to crank/cam sensor harness is rubbing through
    ~James~ Psychotic Gearhead
  3. #3 Re: 2007 GP randomly dies
    Jan 2021
    US
    Thanks, I'll check that out but I get no shuddering or warning before it dies...its either running or not while idling or cruising.
  1. randomly dies...ideas???
    By simon8957 in forum General Grand Prix Discussion
    Last Post: 06-09-2017, 03:04 PM
  2. Engine dies randomly, but starts right back up
    By habbiflyer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-08-2013, 01:57 PM
  3. Car dies randomly, please help!
    By car illiterate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2013, 05:07 PM
  4. 06 grand prix randomly dies...
    By 06pr1x in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2012, 08:33 PM
  5. Car dies randomly.
    By AnalyzeFaith in forum General Tech Discussion
    Last Post: 02-03-2011, 12:08 PM
