Thread: 2006 Grand Prix running hot
Results 1 to 10 of 10
  1. #1 2006 Grand Prix running hot
    Sep 2012
    United States
    My son has a 2006 Grand Prix 3800. He has only had it a few weeks, but it had been sitting for a couple years before he got it. We have flushed the coolant system , replaced the fans and the thermostat, but it still runs pretty hot. Anything else we should check?
  2. #2 Re: 2006 Grand Prix running hot
    Apr 2014
    commerce twp,mi
    water pump could be headed south but first things first:
    define "pretty hot."how is that determined?
    tell us how the flush was done.
    08 grand prix NA3800
  3. #3 Re: 2006 Grand Prix running hot
    St. Louis
    Did you follow the proper cooling system bleed procedure? These motors are prone to air pockets that will cause the temps to be all over the place.
    Beyond that the fan settings are around the 200* mark. Can't remember the low and high settings off the top but they may seem high if you're new to the car. The other thing that can effect it is the Coolant Temp sensor.
  4. #4 Re: 2006 Grand Prix running hot
    GTP Level Member
    Oct 2014
    I have had 4 GP’s and they all seem to run hotter than I would have liked.
  5. #5 Re: 2006 Grand Prix running hot
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    Bleeding the system is key, and can take a couple rounds and pulsing hoses to get it right. You should see it get to around the 195 thermostat mark, and only get about 15-20deg higher under traffic/etc. conditions, and when using the A/C for long stretches. Also, if the car overheats too much, some thermostats can lock open and no longer regulate the coolant flow.
    The water pump will usually weep out the front as an indicator of failure, but other issues also happen. Any sign of a leak after it's closed up needs addressing.
    Radiator fans supplement cooling some, but with the stock settings and 195 degF thermostat, they usually only kick on at low speed for most operating conditions (I'd have to dig up stock settings to see what they were).
    Good luck, and hope you get it settled out.
  6. #6 Re: 2006 Grand Prix running hot
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    My stock fan setting were low speed fan kicked on at 212* and high speed was supposedly 220 but usually never got that high at idle would go up to 215 and slowly drop back to 195 or so. My 2000 reads 20 * warmer than it actually is. So I use my scan tool to read coolant Temps
    Sent from my SM-G973U using Tapatalk
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  7. #7 Re: 2006 Grand Prix running hot
    Aug 2016
    Little Rock, AR
    Watch for blown head gasket. I my son's car ran hot too. I had hoped it would last until he was out of college...but he's taking longer to get out of college than I wanted.
    $2400-2800 to replace the head gasket.
    Anyone need a parts car?
  8. #8 Re: 2006 Grand Prix running hot
    GT Level Member mguzzo's Avatar
    Buffalo NY
    Quote Originally Posted by ARLibertarian View Post
    That's a DIY job if anything. less than a day and less than $200 in parts
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  9. #9 Re: 2006 Grand Prix running hot
    St. Louis
    I'd test the cooling system for exhaust gas before jumping to a blown headgasket, especially on these motors since it's just not that common. It does happen but it's not very often unless it's been overheated a bunch of times.
    If it truly is a HG then I'd just yank the heads and replace the gaskets and headbolts (they are TTY bolts) and call it a day. Can be done with basic tools other than the torque angle meter needed for the headbolts. If done yourself will come in way under that $2400 mark.
  10. #10 Re: 2006 Grand Prix running hot
    Apr 2014
    commerce twp,mi
    dont think ive read or heard of head gasket problems with the GPs
  1. 2006 grand prix
    By That06basemodeltho in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2016, 09:47 AM
  2. 2006 Grand Prix
    By MissChelsea in forum Members Rides
    Last Post: 12-08-2011, 09:58 PM
  3. 2006 Grand prix running Hot..
    By TerryH in forum General Tech Discussion
    Last Post: 07-09-2011, 01:46 PM
