Thread: hole forming inside of the PCV housing attached to intake plenum.
Results 1 to 4 of 4
Threaded View
  1. #1 hole forming inside of the PCV housing attached to intake plenum.
    Feb 2009
    Marengo
    I have a 2002 Grand Prix with 140,000 miles. Has anyone ever heard of a hole forming inside of the PCV housing? This hole isn't normal, right? As shown in the attached pic, the hole is between the PCV housing and the intake plenum. I'm not sure if the hole goes into any of the plenum chambers, but I noticed quite a bit of oil on the PCV valve.The car is giving a P0102 code (Mass or Volume Circuit Low Input) and a rough idle. I was told that the reference voltage for the MAF sensor is controlled by the MAP sensor above the PCV valve, making it possible for a faulty MAP sensor to create a MAF error code. I heard of many issues with these plenums, but not this. Any one know how this may have happen? I don't want to replace it and have it happen again.
  1. Cubby hole to left of the steering wheel
    By RichCresci in forum Visual/Body Modifications
    Last Post: 01-29-2012, 12:47 AM
  2. Making a bigger cubby hole in center console [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 02-28-2009, 11:11 PM
  3. hole in the intake plenum inside pcv housing??
    By Rick C in forum Introductions/Noob Questions
    Last Post: 02-15-2009, 06:03 PM
  4. Supercharger Fill Hole Bolt Stripped
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 06:20 AM
