Thread: 05 gp unknown noise
Results 1 to 9 of 9
  1. #1 05 gp unknown noise
    Oct 2018
    Tn
    Was thinking trans but am unsure. Hoping someone else has heard this and it's minor. Mostly occurs around 2200 rpm.
    https://youtu.be/7UJgoHY9lwE
    P1811
    P0420
  2. #2 Re: 05 gp unknown noise
    sounds like your dragging the muffler down the road.
  3. #3 Re: 05 gp unknown noise
    HUDSON
    Sounds like a cat. converter rattling, specifically the matrix has possibly broken apart and is rattling around inside, or you maybe have an exhaust pipe dragging the ground.
  4. #4 Re: 05 gp unknown noise
    Should we ask... what's the check engine light on for?
  5. #5 Re: 05 gp unknown noise
    Oct 2018
    Tn
    Muffler definitely isn't dragging, cel was cat , I don't recall which code specifically but I'll have it read omw to work and update tonight
  6. #6 Re: 05 gp unknown noise
    May 2008
    Schuyler, NE
    Maybe brakes?
  7. #7 Re: 05 gp unknown noise
    Oct 2018
    Tn
    Within the last 10 days, front and rear pads changed, thermostat replaced, water pump replaced, tensioner pulley assembly replaced and heater core bypassed. After water pump CEL went out for aprox 3 days then reappeared after running a little hot due to coolant leak in heater core caused air bubble. Bled air car runs within normal heat parameters .Seafoamed intake 8 oz , 3oz in crankcase and remaining 5oz in fuel tank. Oil change this weekend possibly trans fluid as well.
  8. #8 Re: 05 gp unknown noise
    maybe a bent dust shield on the brakes. mine got pushed in over winter when i got it some what stuck in deep snow.
    put the car on jack stands and fire it up and put it in gear, listen for the noise.
  9. #9 Re: 05 gp unknown noise
    Oct 2018
    Tn
    Perhaps , wouldn't hurt to check I reckon. It's intermittent and seems to occur at a specific rpm, so when the engine resonates around 2k the rattle becomes noticeable. Imma punch that cat and see what I hear inside . I'm thinking something loose or broken in that general area.
  1. Unknown issue
    By mrdbaby in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-24-2013, 06:08 PM
  2. unknown part
    By Tareksalem in forum General Grand Prix Discussion
    Last Post: 06-13-2013, 01:18 PM
  3. Unknown component
    By terrellc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-10-2012, 01:24 AM
  4. Unknown Noise
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 05-07-2012, 08:49 AM
  5. Unknown Vibration
    By Darkcelle in forum Brakes/Suspension/Chassis
    Last Post: 04-14-2009, 08:07 PM
