Thread: Massive oil leak
Results 1 to 12 of 12
  1. #1 Massive oil leak
    Donating User
    Jul 2014
    Minnesota
    So I have a 00 GT with about 144k on it and today I was out doing some WOT runs and after the second one my oil pressure light came on. So I limped it home and popped the hood and there was a lot of smoke and then I saw on the back right (passenger) side of the motor and firewall was soaked in oil. Looked underneath and the whole underbody was covered in oil and was leaking pretty good. I didn't have a chance to look closer into it because it was dark. I am just wondering what on the backside of the motor could have blown out due to beating on it.
    00 Red GT - ZZP PCM, ZZP HV TB, TRANSGO kit, GMPP Sway Bars, Strut Tower Braces,
  2. #2 Re: Massive oil leak
    Oil pressure switch will piss oil straight out the sensor.
    Oil filter can leak and the oil filter housing can piss oil out all over the passenger side.
    Clean it up, add some oil and see what one it is. My guess is the switch.
  3. #3 Re: Massive oil leak
    Donating User
    Jul 2014
    Minnesota
    Ya I didn't think to check the oil filter housing because all of the oil was on the back side and the oil filter is more towards the front, like I said, I wasn't really able to look too far into it yet.
  4. #4 Re: Massive oil leak
    Donating User
    Jul 2014
    Minnesota
    After doing a little research it is sounding a lot like the oil pressures switch, mainly because the car ran normally after the light came on. Hopefully that is all it is, seems pretty easy to replace.
  5. #5 Re: Massive oil leak
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Hopefully you didn't actually run it low on oil! Though I'm guessing that you checked it before you kept driving. I hope that's all it was!
  6. #6 Re: Massive oil leak
    Donating User
    Jul 2014
    Minnesota
    Well I drove it about a quarter of a mile or so back to my dad's house where I parked it. I cannot say what the oil level is right now but it still sounded and felt normal when I parked. Upon leaving (with a different car) I drove the road that I was doing the WOT runs on and I saw an oil trail for a pretty long way so who knows. I will know more tomorrow when I can go take a look at it.
  7. #7 Re: Massive oil leak
    Donating User
    Jul 2014
    Minnesota
    I live about 30 miles from my dad's house, where the car is now, so it is parked and sitting for now. Wasnt going to try to limp it all the way home.
  8. #8 Re: Massive oil leak
    Aug 2017
    Raytown, MO
    Well I wish you luck! I would be less concerned and pessimistic if I hadn't personally seen the aftermath of running low on oil for only a short drive did to my original engine, but it can't be as bad as that (hint, the connecting rods of 1 and 2 collided). I'm so paranoid now, I carry a quart of every fluid my car needs in the trunk along with a fire extinguisher and a tool kit!
  9. #9 Re: Massive oil leak
    Donating User
    Jul 2014
    Minnesota
    Well thank you, I will get oil in it tomorrow and look for a leak. Hopefully, it doesn't need a motor but if it does I might as well go L67.
  10. #10 Re: Massive oil leak
    Aug 2017
    Raytown, MO
    Quote Originally Posted by 00RedfireGT View Post
    my single biggest regret ever! yes go L67 if it's blown, but it sound like you'll be ok
  11. #11 Re: Massive oil leak
    Donating User
    Jul 2014
    Minnesota
    Haha thanks, my brother is a mechanic so we will see
  12. #12 Re: Massive oil leak
    Donating User
    Jul 2014
    Minnesota
    It was the oil pressure switch. Took the passenger side wheel off started it up and oil started pouring out. Get the old one out and got a new one in in less than 10 mins. Thanks for all the help.
  1. Massive Audio NX5
    By rynoman03 in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2015, 03:37 AM
  2. 2004 GTP massive hesitation
    By YeahRight in forum General Tech Discussion
    Last Post: 09-23-2014, 09:16 PM
  3. Massive Oil Leak
    By 2000superGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2011, 11:17 PM
  4. Massive water leak
    By hahaha38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2010, 07:19 PM
  5. WOAH! Massive Oil Leak!
    By CSteen85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2010, 12:30 AM
