Thread: coolant leaking? passenger side block wet
Results 1 to 20 of 21
Threaded View
  1. #1 coolant leaking? passenger side block wet
    Sep 2011
    Mtl
    Hi there,
    2007 GP, with 126k kms. For years the coolant reservoir level would drop a little, having to top up, now.
    We changed the elbows several years ago, but I'm not sure if its that, we used oem ones.
    I've noticed the black plastic shield at the bottom spots, more now, the rad hose has some now,
    underneath the overflow tube was a bit sticky,
    Since we got the car, brown residue in rad cap/air, like a slow air leak.
    Video
    https://drive.google.com/file/d/0B22...ew?usp=sharing
    This is is very wet behind, maybe the lower rad hose?
    Thank you
    coolant leaking? passenger side block wet Attached Images
  1. LIM side coolant port modification / coolant block off
    By 2004l67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2015, 02:56 PM
  2. Overheating and coolant leaking at corner of the block & manifold
    By kidkev in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2014, 12:47 PM
  3. Antifreeze on the passenger side of the engine block
    By nasa in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-25-2014, 10:16 AM
  4. Leaking fuel from passenger side of engine!
    By 97gtpfreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2012, 12:10 PM
  5. coolant is still leaking around LIM at passenger side
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2010, 10:11 PM
