Thread: Power Windows
Results 1 to 6 of 6
  1. #1 Power Windows
    Jersey
    So my gf has been driving my 97 SE for a while now. She gives me a call and tells me the front driver side window went down by itself. So I unplugged the connection from the motor. Cool right? Now today she gives me another call and tells me the back driver side window did the same thing. What the hell is going on??
  2. #2 Re: Power Windows
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Nope. This is a common problem on these cars. It's your window regulator 99% of the time. Usually you can see the broken cable when you take the panel off. If the connector came loose, the window wouldn't just drop.
  3. #3 Re: Power Windows
    Jersey
    That's the thing. The connector isn't loose from the motor. I unplugged it because the window will go down even if I press the up switch. The only way I could keep it up is to press the switch, while the key is in ACC mode, until the window reached the top. Then I took the key out and unplugged it. So now I have to look at the regulator again smh. I've been changing regulators on this car too much.
  4. #4 Re: Power Windows
    St. Louis
    If you've been eating regulators then I'd make sure all the channels are clean and then lube them with a DRY lube, like graphite spray. A silicone based lube will work but it attracts dirt and then gums up, putting you right back where you started.
    And check the wipes at the top edge of the door as well. It seems that the slightest bit of resistance on these things causes the regulators to die. When I had my door panels all off for the interior rebuild I lubed/cleaned all of the channel I could feel, some was in the door and could not be seen, but could feel it. All 4 windows work like a champ and are actually faster going up than when I got the car.
    And once you do enough regulators you should be able to do a door in about 20 min taking your time, lol.. Gets kinda old after a while I know.
  5. #5 Re: Power Windows
    Jersey
    Ok will do..thanks guys for your input. Fordman you're so right about installing in 20 minutes. It's embedded in my brain lol. I taped off the rear driver door for now. The switch works going down but no power going up. As for the front driver window..I'm still curious as to why the window would suddenly go down by itself when the regulator is intact. Hmmm😕
  6. #6 Re: Power Windows
    St. Louis
    So the window motor will roll the window down all on it's own? Without pressing the button? If so, then I'd be checking either the window motor or the master switch on the drivers door. Might be a short in one of them. My gut says it's an issue with the master switch if it's doing it all by itself. These motors usually just work or they don't.
  1. power windows
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 02-13-2016, 06:41 PM
  2. Power Windows ... Wtf am I looking at?
    By JayHerlth in forum General Tech Discussion
    Last Post: 06-23-2014, 02:36 PM
  3. Windows Have No Power
    By Solid Steel in forum Audio, Security & Visual Electronics
    Last Post: 04-16-2012, 02:03 PM
  4. Power Windows
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-12-2008, 08:51 PM
  5. Power Windows
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-08-2008, 03:58 AM
