Thread: 08 front end noise
Results 1 to 13 of 13
  1. #1 08 front end noise
    Jun 2017
    El Reno
    Hey all. Hopefully you can help me. I have recently started hearing a noise from the font end of my car. It's kind if hard to explain the noise. I'm do my best. It's kind of like a hum that winds up as I go faster, and down when I slow down. It almost sounds like when you put a card in a bike wheel, in the sense that it's kind of a slow and deep noise at first, but as I accelerate, it gets faster and higher pitched. It's definitely not an engine noise. It's also not a bad hub, as I changed them out recently.
    Things I have checked:
    I checked the hubs by jacking it up and looking for play. Good there. I also put the car on stands, turned her on and gave it gas to turn the wheels, in neutral. I don't hear the noise from the wheels, it seems to be coming from somewhere between the wheels, under the car.
    Any help? What can I check? How can I check it. Etc. I don't like taking it to the shop if I can do it. Thanks.
  2. #2 Re: 08 front end noise
    GT Level Member mguzzo's Avatar
    Buffalo NY
    even if there's no play, the hub bearing could still be making noise. Does the noise change going around a corner? For example if the left hub bearing is going, it will get quieter on a right turn because the left hub will get loaded with weight transfer.
    or maybe a tire has a bad belt. try swapping tires front to back and see if the noise move
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: 08 front end noise
    Grab the coil spring on the strut while you spin the tire by hand, you'll feel the vibration through the spring and find the bad bearing.
  4. #4 Re: 08 front end noise
    Jun 2017
    El Reno
    As I said in the post, the sound is not coming from the wheel or the hub. I know what sound a bad bearing makes, and that turning the wheels can help determine. So what else can it be, besides the bearings.
    About the tires, it still made the noise while it was jacked up so I don't think it is the tire, but I'll rotate them anyway.
  5. #5 Re: 08 front end noise
    May 2017
    Dirtyzville, Mizzery
    Axle?
    Input shaft?
    Control Arm?
    I'm just naming anything that moves there.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  6. #6 Re: 08 front end noise
    May 2016
    Burns City, Indiana
    Even if new hubs, if you mis-torqued you can have bearing issues. Also there is guarantee that bearings will make noise a specific way when turning. Proper torque on axle nuts is critical. I know some say just hit it with impact but honestly I have had several get damaged just that way with too tight or too loose.
    Tires whining try maxing tire pressure out and see if its better/less
  7. #7 Re: 08 front end noise
    Jun 2017
    El Reno
    Quote Originally Posted by MonzaRacer View Post
    I torqued both nuts to specs. Also, the noise is not coming from the tires. I jacked the car up, put the car in neutral and had a friend slightly give it gas. Just enough for noise to start. And it is coming from under the car, between the wheels. Not sure exactly where, but definitely not the wheels.
  8. #8 Re: 08 front end noise
    Well, inbetween the wheels is the transmission. That is likely where the noise is then.
  9. #9 Re: 08 front end noise
    Buffalo NY
    Maybe you're low on fluid and you hear the trans pump.
  10. #10 Re: 08 front end noise
    Jun 2017
    El Reno
    The sound was similar to bad cv joints. My friend mentioned it. I changed them, but no go.
  11. #11 Re: 08 front end noise
    May 2016
    Burns City, Indiana
    Well I'm beginning to think your hearing road noise NOT a mechanical one.
  12. #12 Re: 08 front end noise
    Jun 2017
    El Reno
    My engine has quite a bit of play. Could that be causing the clicking noise? Would I be able to hear that?
  13. #13 Re: 08 front end noise
    Aug 2016
    Maricopa, AZ
    You sure it isn't the power steering pump you are hearing?
  1. Front end noise..
    By jprinc06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2015, 12:20 PM
  2. New front brakes and now a squeaking noise up front
    By Trann14 in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2013, 08:45 PM
  3. Front End Noise
    By dlsr in forum General Grand Prix Discussion
    Last Post: 07-11-2012, 12:52 AM
  4. Front end noise
    By GTP2188 in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2011, 01:06 PM
  5. front end noise, what else...?
    By Jakegday in forum General Tech Discussion
    Last Post: 07-30-2010, 08:22 PM
