Thread: 2006 Grand Prix Timing chain scraping on front cover
Results 1 to 18 of 18
  1. #1 2006 Grand Prix Timing chain scraping on front cover
    Feb 2017
    Iowa
    As the title says the timing chain is scraping on the front cover. We've changed the timing chain and gear and put on a ZZP Double thick gasket and it still scrapes. When we tore it apart to change the timing chain gasket because it was leaking it didn't scrape so I have no idea why it is now scraping, the noise isn't coming from anything belt related either, What could it be scraping on? I'm clueless.
  2. #2 Re: 2006 Grand Prix Timing chain scraping on front cover
    Oct 2013
    Clovis, California USA
    Are you sure you got the timing chain/gear set pushed all the way onto the camshaft and crankshaft? That's the only thing I can think of.
  3. #3 Re: 2006 Grand Prix Timing chain scraping on front cover
    May 2008
    Schuyler, NE
    The stock style chain is hitting the cover?
  4. #4 Re: 2006 Grand Prix Timing chain scraping on front cover
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Right. I'm not sure that's where the noise is.
    Have a stethoscope or long screwdriver?
  5. #5 Re: 2006 Grand Prix Timing chain scraping on front cover
    Feb 2017
    Iowa
    Quote Originally Posted by J7319M View Post
    Its pushed back all the way.
  6. #6 Re: 2006 Grand Prix Timing chain scraping on front cover
    Feb 2017
    Iowa
    Yes, stock style chain
  7. #7 Re: 2006 Grand Prix Timing chain scraping on front cover
    May 2008
    Schuyler, NE
    Where is it hitting at? On the crank area or cam?
  8. #8 Re: 2006 Grand Prix Timing chain scraping on front cover
    stupid question, but what was the condition of the dampner?
  9. #9 Re: 2006 Grand Prix Timing chain scraping on front cover
    Feb 2017
    Iowa
    It is scraping on the oil pump cover.
  10. #10 Re: 2006 Grand Prix Timing chain scraping on front cover
    Feb 2017
    Iowa
    Quote Originally Posted by fst View Post
    Brand new
  11. #11 Re: 2006 Grand Prix Timing chain scraping on front cover
    May 2008
    Schuyler, NE
    Quote Originally Posted by ttedesco View Post
    A stock chain should never hit there. Does your crank have a lot of endplay?
  12. #12 Re: 2006 Grand Prix Timing chain scraping on front cover
    Feb 2017
    Iowa
    No it doesn't move at all.
  13. #13 Re: 2006 Grand Prix Timing chain scraping on front cover
    May 2008
    Schuyler, NE
    When did you start having the problem?
  14. #14 Re: 2006 Grand Prix Timing chain scraping on front cover
    Feb 2017
    Iowa
    I had to change the timing chain cover gasket because it was leaking coolant from behind the cover.
  15. #15 Re: 2006 Grand Prix Timing chain scraping on front cover
    May 2008
    Schuyler, NE
    Did you replace the chain at the same time? Or was that later?
  16. #16 Re: 2006 Grand Prix Timing chain scraping on front cover
    Feb 2017
    Iowa
    At first I didn't change the timing chain but after it made the scraping noise I put a new chain on and after putting a new chain on it is still making the scraping sound.
  17. #17 Re: 2006 Grand Prix Timing chain scraping on front cover
    May 2008
    Schuyler, NE
    I don't really know what else to tell you. There is a ton of room in there so it should never even be close to touching. Something has to be installed incorrectly.
  18. #18 Re: 2006 Grand Prix Timing chain scraping on front cover
    Mar 2017
    Internet
    Are you positive it's the chain and not one of the tabs on the back of the balancer that got bent and is hitting the crank sensor?
  1. Coolant leak from Timing Chain Cover??
    By wb22rules in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-01-2017, 04:06 PM
  2. Rollmaster timing chain w/ machined pump cover.
    By BoostedPontiac in forum For Sale - Parts
    Last Post: 10-16-2014, 07:44 PM
  3. Timing Chain cover
    By brichter45 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-08-2013, 12:11 PM
  4. Timing Chain cover
    By timboku in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2010, 10:02 PM
