Thread: Cleaning Intake Ports
Results 1 to 5 of 5
  1. #1 Cleaning Intake Ports
    May 2012
    Bloomington, IN
    I'm doing a LIM gasket and I was wondering if there is a good way of cleaning out the intake ports on the cylinder head. I wasn't sure if I could just spray it down with intake cleaner or if that will just gum up the area around the valves. I know there are different kinds of intake cleaner one which is used with the engine running. But I wanted to know if there would be any harm to cleaning out the intake ports when I have everything apart, thanks.
  2. #2 Re: Cleaning Intake Ports
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    I wouldn't unless your going to take the heads off anything you spray is just going to go down into the engine and make it worse then before.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  3. #3 Re: Cleaning Intake Ports
    They shouldn't be too dirty because the fuel injector sprays the fuel right into the cylinder head before the intake valve.
    Brake cleaner and a scraper if you want, then vacuum anything you can out or use a pick.
  4. #4 Re: Cleaning Intake Ports
    If anything, clean the throttle body, LIM, and all the corresponding sensors.
    Cleaning the intake ports on the heads...unless you're going totally through the engine, isn't worth the time.
  5. #5 Re: Cleaning Intake Ports
    Oct 2013
    Clovis, California USA
    I just got through doing this last week. I used a combination of gasoline, a tooth brush and an acid brush to get the black carbon off. For the reddish brown stains left behind, I used a brass wire brush and carb cleaner. Turned out real well.
  1. intake ports after running E85 for a couple months, PICS
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2013, 11:41 PM
  2. specifications for ports
    By SmitysGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 10:30 AM
  3. Silencer ports...
    By WHT98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2011, 12:09 AM
  4. USB Ports
    By Shotime216 in forum Visual/Body Modifications
    Last Post: 06-13-2011, 01:41 AM
  5. '00 Grand Prix GT intake/cleaning ?'s
    By blueGT00 in forum General Tech Discussion
    Last Post: 03-28-2011, 09:25 PM
