Thread: Service vehicle
Results 1 to 5 of 5
  1. #1 Service vehicle
    Jan 2016
    Oregon
    The "service vehicle soon" reading came up on my 06 gp, the check engine light isnt on though, it only reads when the key is only turned 1 notch and not when the car is on. Any idea why this happened? If I take it to autozone can they give me a code or is thag only for check engline lights
  2. #2 Re: Service vehicle
    You sure it's not a service light for like an oil change??
    Possible there is a code but no likely if the check engine light itself is not on.
  3. #3 Re: Service vehicle
    St. Louis
    Take a read through this thread. Could be a code that a Tech-II needs to read--> http://www.grandprixforums.net/threa...e-Soon-Message
  4. #4 Re: Service vehicle
    Pennsylvania, USA
    I've had the same message pop up for the past year or so. I suspect a body electrical/BCM code to be triggering it because I don't have any powertrain or ABS codes stored. Check all your exterior lighting to rule that out, otherwise it probably needs to be scanned with a Tech-II as FordMan said.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  5. #5 Re: Service vehicle
    Jan 2016
    Oregon
    Ok I'll check it out, thanks
  1. 06 grand prix gxp service vehicle soon light??
    By 06pontiacgxp in forum General Grand Prix Discussion
    Last Post: 06-23-2016, 03:48 PM
  2. Service Vehicle Soon (but no check engine light)
    By ThaUnknownOne in forum 5.3L V8 (LS4)
    Last Post: 10-21-2013, 11:30 AM
  3. Service Vehicle Soon Message.
    By Jake U in forum General Grand Prix Discussion
    Last Post: 07-15-2013, 03:07 PM
  4. Service Vehicle Soon message
    By talltree in forum General Tech Discussion
    Last Post: 06-27-2013, 09:02 AM
  5. Service Vehicle Soon Light, No Codes
    By Luda in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-16-2009, 10:03 AM
